Webcam Prolem
Hi together,
i always get on records "input.txt: Invalid data found when processing input"
Can someone help me.
Best Regards
Björn
  • Check the directory where it is stored if it contains all images mentioned in input.txt - I think it comes from missing images when webcam is not reachable. folder is storgeDir/printer/PrinterSlug/timelapse
  • When repetier Record there is an Image no Camera but when i go to the Webcam there is a snooth video
  • Think I got the problem forgot the @make_snapshot *facepalm*
  • When you go to printer configuration->webcams do you see also an image for the jpg part? Stream and capture use different url and it sounds like the capture url is not correctly set.
  • I got it it was the no @make_snapshot.
