Druck bricht kurz nach dem Start ab: Receiving only error messages. Reset communications for printer
Guten Tag,
ich seit kurzem das Problem, das ich im Repetier Server den Druck starte und kurz darauf wird er abgebrochen mit folgendem Fehler:
Receiving only error messages. Reset communications for printer Anycubic.
Folgendes steht in der Log Datei:
Send:14:46:37.872: N15 M75 AI3MSPRO_Griff_Wäsch
Send:14:46:37.872: N16 M73 P0 R302 Q0 S302
Recv:14:46:37.875: Error:Serial status mismatch
Recv:14:46:37.877: Error:checksum mismatch, Last Line: 14
Recv:14:46:37.877: Resend: 15
Recv:14:46:37.879: Ignore due to resend: ok
Recv:14:46:37.890: Waiting for resend requests finished. Starting resends ...
Send:14:46:37.891: Resend: N15 M75 AI3MSPRO_Griff_Wäsch
Recv:14:46:37.893: Error:Serial status mismatch
Recv:14:46:38.568: T:16.84 /0.00 B:41.76 /0.00 @:0 B@:0
Recv:14:46:39.568: T:16.33 /0.00 B:41.75 /0.00 @:0 B@:0
Recv:14:46:40.568: T:16.45 /0.00 B:41.49 /0.00 @:0 B@:0
Recv:14:46:41.569: T:16.84 /0.00 B:41.47 /0.00 @:0 B@:0
Recv:14:46:42.569: T:16.87 /0.00 B:41.47 /0.00 @:0 B@:0
Recv:14:46:43.569: T:16.29 /0.00 B:41.47 /0.00 @:0 B@:0
Recv:14:46:44.569: T:16.80 /0.00 B:41.47 /0.00 @:0 B@:0
Recv:14:46:45.569: T:16.48 /0.00 B:41.47 /0.00 @:0 B@:0
Recv:14:46:46.569: T:16.52 /0.00 B:41.47 /0.00 @:0 B@:0
Mesg:14:46:46.893: Warning: Communication timeout - resetting communication buffer.
Mesg:14:46:46.893: This means that a expected firmware response was not seen within the expected time.
Mesg:14:46:46.893: The typical reason is a communication error and print should continue after the communication reset.
Mesg:14:46:46.893: Connection status: Buffered:34, Manual Commands: 1, Job Commands: 5000
Mesg:14:46:46.893: Buffer used:34 Enforced free byte:0 lines stored:1
Send:14:46:46.893: Resend: N16 M73 P0 R302 Q0 S302
Send:14:46:46.893: M117 ETA 19:48:21 day 10
Send:14:46:46.893: N17 M82 ;absolute extrusion mode
Send:14:46:46.893: N18 G21                                        ; metric values
Send:14:46:46.893: N19 G90                                        ; absolute positioning
Send:14:46:46.893: N20 M82                                        ; set extruder to absolute mode
Send:14:46:46.893: N21 M107                                       ; start with the fan off
Send:14:46:46.894: Slow command added:M190 S60   ; preheat and wait for bed
Send:14:46:46.894: N22 M190 S60   ; preheat and wait for bed
Send:14:46:46.894: N23 M73 P2 R296 Q2 S296
Send:14:46:46.894: Slow command added:M109 S205 ; preheat and wait for hotend
Send:14:46:46.894: N24 M109 S205 ; preheat and wait for hotend
Send:14:46:46.894: Slow command added:M300 S1000 P500                            ; BEEP heating done
Send:14:46:46.894: N25 M300 S1000 P500                            ; BEEP heating done
Send:14:46:46.894: Slow command added:G28 X0 Y10 Z0                              ; move X/Y to min endstops
Send:14:46:46.894: N26 G28 X0 Y10 Z0                              ; move X/Y to min endstops
Send:14:46:46.894: N27 M114
Recv:14:46:46.896: Error:checksum mismatch, Last Line: 14
Recv:14:46:46.898: Resend: 15
Recv:14:46:46.900: Ignore due to resend: ok
Recv:14:46:46.900: Ignore due to resend: Error:Line Number is not Last Line Number+1, Last Line: 14
Recv:14:46:46.902: Ignore due to resend: Resend: 15
Recv:14:46:46.902: Ignore due to resend: ok
Recv:14:46:46.904: Ignore due to resend: echo:Unknown command: "2"
Recv:14:46:46.904: Ignore due to resend: ok
Recv:14:46:46.906: Ignore due to resend: Error:Line Number is not Last Line Number+1, Last Line: 14
Recv:14:46:46.906: Ignore due to resend: Resend: 15
Recv:14:46:46.906: Ignore due to resend: ok
Recv:14:46:46.918: Waiting for resend requests finished. Starting resends ...
Send:14:46:46.918: Resend: N15 M75 AI3MSPRO_Griff_Wäsch
Recv:14:46:46.921: Error:Serial status mismatch
Recv:14:46:47.570: T:16.80 /0.00 B:41.38 /0.00 @:0 B@:0
Recv:14:46:49.287: T:16.37 /0.00 B:41.34 /0.00 @:0 B@:0
Recv:14:46:50.286: T:16.41 /0.00 B:41.23 /0.00 @:0 B@:0
Recv:14:46:51.287: T:16.72 /0.00 B:41.19 /0.00 @:0 B@:0
Recv:14:46:51.909: echo:busy: processing
Recv:14:46:52.286: T:16.52 /0.00 B:41.18 /0.00 @:0 B@:0
Recv:14:46:53.287: T:16.72 /0.00 B:41.18 /0.00 @:0 B@:0
Recv:14:46:54.288: T:16.64 /0.00 B:41.18 /0.00 @:0 B@:0
Recv:14:46:55.288: T:16.76 /0.00 B:41.18 /0.00 @:0 B@:0
Recv:14:46:56.288: T:16.76 /0.00 B:41.08 /0.00 @:0 B@:0
Recv:14:46:56.910: echo:busy: processing
Recv:14:46:57.288: T:16.68 /0.00 B:40.92 /0.00 @:0 B@:0
Recv:14:46:58.289: T:16.76 /0.00 B:40.97 /0.00 @:0 B@:0
Recv:14:46:59.288: T:16.60 /0.00 B:40.88 /0.00 @:0 B@:0
Recv:14:47:00.289: T:16.80 /0.00 B:40.88 /0.00 @:0 B@:0
Recv:14:47:01.290: T:16.60 /0.00 B:40.88 /0.00 @:0 B@:0
Recv:14:47:01.912: echo:busy: processing
Recv:14:47:02.290: T:16.68 /0.00 B:40.88 /0.00 @:0 B@:0
Recv:14:47:03.290: T:16.76 /0.00 B:40.85 /0.00 @:0 B@:0
Recv:14:47:04.290: T:16.76 /0.00 B:40.83 /0.00 @:0 B@:0
Recv:14:47:05.291: T:16.76 /0.00 B:40.70 /0.00 @:0 B@:0
Recv:14:47:06.290: T:16.72 /0.00 B:40.68 /0.00 @:0 B@:0
Recv:14:47:06.914: echo:busy: processing
Recv:14:47:07.291: T:16.80 /0.00 B:40.59 /0.00 @:0 B@:0
Recv:14:47:08.291: T:16.64 /0.00 B:40.61 /0.00 @:0 B@:0
Recv:14:47:09.291: T:16.68 /0.00 B:40.59 /0.00 @:0 B@:0
Recv:14:47:10.292: T:16.87 /0.00 B:40.57 /0.00 @:0 B@:0
Recv:14:47:11.292: T:16.76 /0.00 B:40.55 /0.00 @:0 B@:0
Recv:14:47:11.914: echo:busy: processing
Recv:14:47:12.292: T:16.68 /0.00 B:40.48 /0.00 @:0 B@:0
Recv:14:47:13.292: T:16.80 /0.00 B:40.48 /0.00 @:0 B@:0
Recv:14:47:13.565: X:2.00 Y:2.00 Z:0.00 E:0.00 Count X:160 Y:160 Z:0
Recv:14:47:13.565: ok
Send:14:47:13.565: Resend: N16 M73 P0 R302 Q0 S302
Recv:14:47:13.569: Error:checksum mismatch, Last Line: 14
Recv:14:47:13.569: Resend: 15
Recv:14:47:13.571: Ignore due to resend: ok
Recv:14:47:13.581: Waiting for resend requests finished. Starting resends ...
Send:14:47:13.582: Resend: N15 M75 AI3MSPRO_Griff_Wäsch
Recv:14:47:13.584: Error:Serial status mismatch
Recv:14:47:14.293: T:16.56 /0.00 B:40.46 /0.00 @:0 B@:0
Recv:14:47:15.292: T:16.87 /0.00 B:40.37 /0.00 @:0 B@:0
Recv:14:47:16.293: T:16.80 /0.00 B:40.33 /0.00 @:0 B@:0
Recv:14:47:17.294: T:16.87 /0.00 B:40.29 /0.00 @:0 B@:0
Recv:14:47:18.294: T:16.84 /0.00 B:40.29 /0.00 @:0 B@:0
Recv:14:47:19.294: T:16.87 /0.00 B:40.29 /0.00 @:0 B@:0
Recv:14:47:20.294: T:16.84 /0.00 B:40.29 /0.00 @:0 B@:0
Recv:14:47:21.295: T:16.84 /0.00 B:40.22 /0.00 @:0 B@:0
Recv:14:47:22.294: T:16.87 /0.00 B:40.22 /0.00 @:0 B@:0
Mesg:14:47:22.587: Warning: Communication timeout - resetting communication buffer.
Mesg:14:47:22.587: This means that a expected firmware response was not seen within the expected time.
Mesg:14:47:22.587: The typical reason is a communication error and print should continue after the communication reset.
Mesg:14:47:22.587: Connection status: Buffered:34, Manual Commands: 2, Job Commands: 5000
Mesg:14:47:22.587: Buffer used:34 Enforced free byte:0 lines stored:1
Send:14:47:22.588: Resend: N16 M73 P0 R302 Q0 S302
Recv:14:47:22.591: Error:checksum mismatch, Last Line: 14
Recv:14:47:22.591: Resend: 15
Recv:14:47:22.594: Ignore due to resend: ok
Recv:14:47:22.604: Waiting for resend requests finished. Starting resends ...
Send:14:47:22.604: Resend: N15 M75 AI3MSPRO_Griff_Wäsch
Recv:14:47:22.607: Error:Serial status mismatch
Recv:14:47:23.295: T:16.87 /0.00 B:40.17 /0.00 @:0 B@:0
Recv:14:47:24.295: T:16.87 /0.00 B:40.06 /0.00 @:0 B@:0
Recv:14:47:25.295: T:16.87 /0.00 B:40.00 /0.00 @:0 B@:0
Recv:14:47:26.296: T:16.87 /0.00 B:40.00 /0.00 @:0 B@:0
Recv:14:47:27.296: T:16.87 /0.00 B:40.00 /0.00 @:0 B@:0
Recv:14:47:28.296: T:16.87 /0.00 B:40.00 /0.00 @:0 B@:0
Recv:14:47:29.296: T:16.87 /0.00 B:39.92 /0.00 @:0 B@:0
Recv:14:47:30.297: T:16.87 /0.00 B:39.83 /0.00 @:0 B@:0
Recv:14:47:31.297: T:16.87 /0.00 B:39.79 /0.00 @:0 B@:0
Mesg:14:47:31.609: Warning: Communication timeout - resetting communication buffer.
Mesg:14:47:31.609: This means that a expected firmware response was not seen within the expected time.
Mesg:14:47:31.609: The typical reason is a communication error and print should continue after the communication reset.
Mesg:14:47:31.609: Connection status: Buffered:34, Manual Commands: 2, Job Commands: 5000
Mesg:14:47:31.609: Buffer used:34 Enforced free byte:0 lines stored:1
Send:14:47:31.609: Resend: N16 M73 P0 R302 Q0 S302
Recv:14:47:31.613: Error:checksum mismatch, Last Line: 14
Recv:14:47:31.613: Resend: 15
Recv:14:47:31.615: Ignore due to resend: ok
Recv:14:47:31.626: Waiting for resend requests finished. Starting resends ...
Send:14:47:31.626: Resend: N15 M75 AI3MSPRO_Griff_Wäsch
Recv:14:47:31.629: Error:Serial status mismatch
Recv:14:47:32.297: T:16.87 /0.00 B:39.77 /0.00 @:0 B@:0
Recv:14:47:33.298: T:16.87 /0.00 B:39.73 /0.00 @:0 B@:0
Recv:14:47:34.298: T:16.87 /0.00 B:39.71 /0.00 @:0 B@:0
Recv:14:47:35.298: T:16.87 /0.00 B:39.67 /0.00 @:0 B@:0
Recv:14:47:36.298: T:16.87 /0.00 B:39.67 /0.00 @:0 B@:0
Recv:14:47:37.299: T:16.87 /0.00 B:39.67 /0.00 @:0 B@:0
Recv:14:47:38.298: T:16.87 /0.00 B:39.65 /0.00 @:0 B@:0
Recv:14:47:39.299: T:16.87 /0.00 B:39.63 /0.00 @:0 B@:0
Recv:14:47:40.299: T:16.87 /0.00 B:39.52 /0.00 @:0 B@:0
Mesg:14:47:40.633: Warning: Communication timeout - resetting communication buffer.
Mesg:14:47:40.633: This means that a expected firmware response was not seen within the expected time.
Mesg:14:47:40.633: The typical reason is a communication error and print should continue after the communication reset.
Mesg:14:47:40.633: Connection status: Buffered:34, Manual Commands: 2, Job Commands: 5000
Mesg:14:47:40.633: Buffer used:34 Enforced free byte:0 lines stored:1
Send:14:47:40.633: Resend: N16 M73 P0 R302 Q0 S302
Recv:14:47:40.637: Error:checksum mismatch, Last Line: 14
Recv:14:47:40.637: Resend: 15
Recv:14:47:40.639: Ignore due to resend: ok
Recv:14:47:40.650: Waiting for resend requests finished. Starting resends ...
Send:14:47:40.650: Resend: N15 M75 AI3MSPRO_Griff_Wäsch
Recv:14:47:40.653: Error:Serial status mismatch
Recv:14:47:41.299: T:16.87 /0.00 B:39.48 /0.00 @:0 B@:0
Recv:14:47:42.300: T:16.87 /0.00 B:39.35 /0.00 @:0 B@:0
Recv:14:47:43.300: T:16.87 /0.00 B:39.33 /0.00 @:0 B@:0
Recv:14:47:44.300: T:16.87 /0.00 B:39.33 /0.00 @:0 B@:0
Recv:14:47:45.300: T:16.91 /0.00 B:39.33 /0.00 @:0 B@:0
Recv:14:47:46.301: T:16.87 /0.00 B:39.33 /0.00 @:0 B@:0
Recv:14:47:47.301: T:16.87 /0.00 B:39.33 /0.00 @:0 B@:0
Recv:14:47:48.301: T:16.87 /0.00 B:39.25 /0.00 @:0 B@:0
Recv:14:47:49.302: T:16.87 /0.00 B:39.21 /0.00 @:0 B@:0
Mesg:14:47:49.655: Warning: Communication timeout - resetting communication buffer.
Mesg:14:47:49.655: This means that a expected firmware response was not seen within the expected time.
Mesg:14:47:49.655: The typical reason is a communication error and print should continue after the communication reset.
Mesg:14:47:49.655: Connection status: Buffered:34, Manual Commands: 3, Job Commands: 7
Mesg:14:47:49.655: Buffer used:34 Enforced free byte:0 lines stored:1
Send:14:47:49.655: Resend: N16 M73 P0 R302 Q0 S302
Recv:14:47:49.659: Error:checksum mismatch, Last Line: 14
Recv:14:47:49.659: Resend: 15
Recv:14:47:49.661: Ignore due to resend: ok
Recv:14:47:49.672: Waiting for resend requests finished. Starting resends ...
Send:14:47:49.672: Resend: N15 M75 AI3MSPRO_Griff_Wäsch
Recv:14:47:49.674: Error:Serial status mismatch
Recv:14:47:50.302: T:16.87 /0.00 B:39.17 /0.00 @:0 B@:0
Recv:14:47:51.303: T:16.95 /0.00 B:39.10 /0.00 @:0 B@:0
Recv:14:47:52.302: T:16.91 /0.00 B:39.04 /0.00 @:0 B@:0
Recv:14:47:53.303: T:16.91 /0.00 B:39.00 /0.00 @:0 B@:0
Recv:14:47:54.302: T:16.91 /0.00 B:39.00 /0.00 @:0 B@:0
Recv:14:47:55.303: T:16.87 /0.00 B:39.00 /0.00 @:0 B@:0
Recv:14:47:56.303: T:16.91 /0.00 B:39.00 /0.00 @:0 B@:0
Recv:14:47:57.304: T:16.87 /0.00 B:39.00 /0.00 @:0 B@:0
Recv:14:47:58.305: T:16.95 /0.00 B:38.98 /0.00 @:0 B@:0
Mesg:14:47:58.678: Warning: Communication timeout - resetting communication buffer.
Mesg:14:47:58.679: This means that a expected firmware response was not seen within the expected time.
Mesg:14:47:58.679: The typical reason is a communication error and print should continue after the communication reset.
Mesg:14:47:58.679: Connection status: Buffered:34, Manual Commands: 3, Job Commands: 7
Mesg:14:47:58.679: Buffer used:34 Enforced free byte:0 lines stored:1
Send:14:47:58.679: Resend: N16 M73 P0 R302 Q0 S302
Recv:14:47:58.683: Error:checksum mismatch, Last Line: 14
Recv:14:47:58.683: Resend: 15
Recv:14:47:58.685: Ignore due to resend: ok
Recv:14:47:58.695: Waiting for resend requests finished. Starting resends ...
Send:14:47:58.695: Resend: N15 M75 AI3MSPRO_Griff_Wäsch
Recv:14:47:58.698: Error:Serial status mismatch
Recv:14:47:59.304: T:16.87 /0.00 B:38.92 /0.00 @:0 B@:0
Recv:14:48:00.305: T:16.87 /0.00 B:38.81 /0.00 @:0 B@:0
Recv:14:48:01.304: T:16.91 /0.00 B:38.69 /0.00 @:0 B@:0
Recv:14:48:02.305: T:16.95 /0.00 B:38.69 /0.00 @:0 B@:0
Recv:14:48:03.305: T:16.95 /0.00 B:38.67 /0.00 @:0 B@:0
Recv:14:48:04.306: T:16.99 /0.00 B:38.67 /0.00 @:0 B@:0
Recv:14:48:05.306: T:16.91 /0.00 B:38.67 /0.00 @:0 B@:0
Recv:14:48:06.306: T:16.95 /0.00 B:38.67 /0.00 @:0 B@:0
Recv:14:48:07.306: T:16.99 /0.00 B:38.67 /0.00 @:0 B@:0
Mesg:14:48:07.700: Warning: Communication timeout - resetting communication buffer.
Mesg:14:48:07.700: This means that a expected firmware response was not seen within the expected time.
Mesg:14:48:07.700: The typical reason is a communication error and print should continue after the communication reset.
Mesg:14:48:07.700: Connection status: Buffered:34, Manual Commands: 3, Job Commands: 7
Mesg:14:48:07.700: Buffer used:34 Enforced free byte:0 lines stored:1
Send:14:48:07.701: Resend: N16 M73 P0 R302 Q0 S302
Recv:14:48:07.705: Error:checksum mismatch, Last Line: 14
Recv:14:48:07.705: Resend: 15
Recv:14:48:07.707: Ignore due to resend: ok
Recv:14:48:07.718: Waiting for resend requests finished. Starting resends ...
Send:14:48:07.718: Resend: N15 M75 AI3MSPRO_Griff_Wäsch
Recv:14:48:07.721: Error:Serial status mismatch
Recv:14:48:08.306: T:17.03 /0.00 B:38.63 /0.00 @:0 B@:0
Recv:14:48:09.307: T:16.95 /0.00 B:38.63 /0.00 @:0 B@:0
Recv:14:48:10.306: T:16.99 /0.00 B:38.54 /0.00 @:0 B@:0
Recv:14:48:11.307: T:17.03 /0.00 B:38.44 /0.00 @:0 B@:0
Recv:14:48:12.307: T:17.07 /0.00 B:38.40 /0.00 @:0 B@:0
Recv:14:48:13.308: T:17.07 /0.00 B:38.33 /0.00 @:0 B@:0
Recv:14:48:14.308: T:17.15 /0.00 B:38.33 /0.00 @:0 B@:0
Recv:14:48:15.308: T:17.11 /0.00 B:38.33 /0.00 @:0 B@:0
Recv:14:48:16.309: T:17.03 /0.00 B:38.33 /0.00 @:0 B@:0
Mesg:14:48:16.723: Warning: Communication timeout - resetting communication buffer.
Mesg:14:48:16.723: This means that a expected firmware response was not seen within the expected time.
Mesg:14:48:16.723: The typical reason is a communication error and print should continue after the communication reset.
Mesg:14:48:16.723: Connection status: Buffered:34, Manual Commands: 3, Job Commands: 7
Mesg:14:48:16.723: Buffer used:34 Enforced free byte:0 lines stored:1
Send:14:48:16.723: Resend: N16 M73 P0 R302 Q0 S302
Recv:14:48:16.727: Error:checksum mismatch, Last Line: 14
Recv:14:48:16.727: Resend: 15
Recv:14:48:16.729: Ignore due to resend: ok
Recv:14:48:16.740: Waiting for resend requests finished. Starting resends ...
Send:14:48:16.740: Resend: N15 M75 AI3MSPRO_Griff_Wäsch
Recv:14:48:16.743: Error:Serial status mismatch
Recv:14:48:17.308: T:17.03 /0.00 B:38.33 /0.00 @:0 B@:0
Recv:14:48:18.309: T:17.03 /0.00 B:38.33 /0.00 @:0 B@:0
Recv:14:48:19.309: T:17.15 /0.00 B:38.31 /0.00 @:0 B@:0
Recv:14:48:20.309: T:17.15 /0.00 B:38.25 /0.00 @:0 B@:0
Recv:14:48:21.310: T:17.15 /0.00 B:38.21 /0.00 @:0 B@:0
Recv:14:48:22.310: T:17.03 /0.00 B:38.13 /0.00 @:0 B@:0
Recv:14:48:23.311: T:17.15 /0.00 B:38.13 /0.00 @:0 B@:0
Recv:14:48:24.310: T:17.19 /0.00 B:38.04 /0.00 @:0 B@:0
Recv:14:48:25.311: T:17.23 /0.00 B:38.00 /0.00 @:0 B@:0
Mesg:14:48:25.745: Warning: Communication timeout - resetting communication buffer.
Mesg:14:48:25.745: This means that a expected firmware response was not seen within the expected time.
Mesg:14:48:25.745: The typical reason is a communication error and print should continue after the communication reset.
Mesg:14:48:25.745: Connection status: Buffered:34, Manual Commands: 3, Job Commands: 7
Mesg:14:48:25.745: Buffer used:34 Enforced free byte:0 lines stored:1
Send:14:48:25.746: Resend: N16 M73 P0 R302 Q0 S302
Recv:14:48:25.750: Error:checksum mismatch, Last Line: 14
Recv:14:48:25.750: Resend: 15
Mesg:14:48:25.750: Receiving only error messages. Reset communication for printer Anycubic i3 Mega S.
Recv:14:48:25.756: Connection verified by:ok
Recv:14:48:25.756: ok
Kommunikationstimeout habe ich schon zum testen erhöht. Der Drucker ging bis vor kurzem Problemlos.
Hab den Drucker dann mal zum testen bei Octoprint angeschlossen und da ging er problemlos.
Ich hab auch noch 2 weitere Drucker am Repetier Server hängen und bei den beiden gibts keine Fehler.
Mit freundlichen Grüßen Daniel
  • Das Problem ist diese Zeile:
    Hier wird der Dateiname übermittelt. ä ist aber kein ascii zeichen was wohl zu dem Problem führt. Da ich das intuitiv vermeide ist es mir och nicht aufgefallen. Werds morgen mal testen, aber ich denke umbenennen der Datei in
    AI3MSPRO_Griff_Waesch
    sollte schon helfen.
    Wenn es das ist werde ich noch was fürs nächste Release ändern - sollte sich ja nicht an unicode verschlucken sondern den in ascii umwandeln.
  • Okay, danke:)
    Werd das morgen mal testen und hier Feedback geben.
  • Habe das gerade mit einem aktuellen Marlin 2 probiert da stört der Dateiname nicht. Welche Marlin Version nutzt du hier?
    Und kannst du z.b.
    M118 Bößer Text
    ohne Fehler schicken?
    Da dein Drucker im checksum Fehler meldet scheint er die Prüfsumme ja falsch zu berechnen. Die Frage ist nur liegt es an den Umlauten oder weil M75 Text enthält was ihm nicht schmeckt. Oder hat die Datei noch mehr zeichen als "AI3MSPRO_Griff_Wäsch" z.b. * was ja die Prüsziffer einleitet.
  • Als Firmware ist Knutwurst 1.4.4 drauf.
    wie gesagt, über Octoprint klappt der druck mit der exakten Datei (gleiche Code)
    Hab jetzt mal eine andere Datei ausgedruckt, die ich schon öfter gedruckt habe, die klappt zum Drucken (hat aber auch kein Ä, Ö,Ü im Dateinamen)
    wenn ich den Code: M118 Bößer Text sende, bekomme ich diese Antwort:
    Recv:11:48:25.285: Error:Serial status mismatch
    Mesg:11:48:34.285: Warning: Communication timeout - resetting communication buffer.
    Mesg:11:48:34.285: This means that a expected firmware response was not seen within the expected time.
    Mesg:11:48:34.285: The typical reason is a communication error and print should continue after the communication reset.
    Mesg:11:48:34.285: Connection status: Buffered:25, Manual Commands: 0, Job Commands: 0
    Mesg:11:48:34.285: Buffer used:25 Enforced free byte:0 lines stored:1
    mfg Daniel
  • Ok, das ist interessant. Mein anycubic Mega S hat auch Marlin von Knutwurst drauf aber basierend auf 2.0.5.4. Da kann ich
    M118 Bößer Text
    senden. Hab dann mal 1.4.4 basierend auf Marlin 2.0.9.2 installiert und dann kann ich den Befehl nicht mehr senden. Gleicher Fehler wie bei dir. Also scheint das marlin in der Version zumindest Probleme mit utf-8 zeichen zu haben. Nicht sehr befriedigend zu wissen das alte und neue versionen es können, aber dazwischen mal Probleme existieren. Weiß man ja nicht wer grad das Problem hat:-( Werd dann wohl non ascii bei marlin generell verbieten müssen damit er keine Probelme bekommt egal bei wem.
  • okay, vielen Dank für deine Hilfe.
    Mfg Daniel
