connection issues w Printrboard
I have a NEW TwoUp 3D printer.
I have everything installed and the port and baud rates match in the systems.
The Teensy board and driver are liked by Windows 7 32 bit in my computer
I am running the latest version of Repetier Host 1.0.3
When I turn power on the printer and Printrboard and load Repetier Host, I can get the green connected light, but when I watch the Log, it does not give the firmware or any other info except for the following...
: OpenGL version:4.3.12618 Compatibility Profile Context 13.251.0.0
: OpenGL extensions:GL_AMDX_debug_output
GL_AMDX_vertex_shader_tessellator GL_AMD_conservative_depth
GL_AMD_debug_output GL_AMD_depth_clamp_separate
GGL_AMD_draw_buffers_blend GL_AMD_multi_draw_indirect
GL_AMD_name_gen_delete GL_AMD_performance_monitor GL_AMD_pinned_memory
GL_AMD_query_buffer_object GL_AMD_sample_positions L_
: OpenGL renderer:AMD Radeon HD 6670
: Using fast VBOs for rendering is possible
: N1 M110 *2
: N1 M110 *2
: N2 M115 *4
: N3 T0 *25
: N4 M105 *3
: N5 M114 *2
: N6 M111 S6 *65
: N7 M20 *54
: N8 M80 *51
: N9 M105 *14
Does this mean that I am not connected to the Printrboard :?  I don't know why it sayds the info about an AMD Radeon 6670 unit, since that sounds like my graphics card...
Any assistance would be great and appreciated.
Thanks,
Mike
  • This may be obvious (though wasn't for me) - did you press "Ok" in the "manual" tab to allow Repetier sending commands to the printer?
  • With printrboard you need to set "Reset on Connect" to disabled. Reset does not work with printrboard.
  • Do you have the red printrboard Mike? I have the red one and Repetier freezes when I press connect. The only way to exit Repetier after it freezes is to unplug the usb and it will automatically crash. Help.
