Can only run Repetier-Host under sudo?
I am running Repetier-Host V2.2.4 and Server V1.4.2 on Linux Mint 20.3 Una.
If I launch Repetier-Host using sudo repetierHost it opens and runs correctly, connects to the server, prints, etc.. However, if I attempt to run it under my user it doesn't start and gives me the following errors:
$repetierHost
$ libpng warning: iCCP: known incorrect sRGB profile
Unhandled Exception:
System.IndexOutOfRangeException: Index was outside the bounds of the array.
  at RepetierHost.view.FormPrinterSettings.comboScripts_SelectedIndexChanged (System.Object sender, System.EventArgs e) [0x0004a] in <63c553364181423faf81fbf20d6b440d>:0
  at RepetierHost.view.FormPrinterSettings.formToCon () [0x0001f] in <63c553364181423faf81fbf20d6b440d>:0
  at (wrapper remoting-invoke-with-check) RepetierHost.view.FormPrinterSettings.formToCon()
  at RepetierHost.view.FormPrinterSettings.LoadDefaultPrinter () [0x00066] in <63c553364181423faf81fbf20d6b440d>:0
  at RepetierHost.Main..ctor () [0x002ac] in <63c553364181423faf81fbf20d6b440d>:0
  at (wrapper remoting-invoke-with-check) RepetierHost.Main..ctor()
  at RepetierHost.Program.Main (System.String[] args) [0x00015] in <63c553364181423faf81fbf20d6b440d>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.IndexOutOfRangeException: Index was outside the bounds of the array.
My username is a member of the tty dialout group so that doesn't appear to be the problem.
The major issue is that I am trying to get access to the slicer g-code files, but they are being saved under root which is complicating access.
  • Sounds like there is some bad setting in your users registry while root is using own registry with different settings. They are atore in home/.mono/ Not sure if Software/repetier or directly but somewhere there. Rename the repetier folder so it thinks it's a new installation and it should start. Then configure again or try finding the offending setting in repetier folder.
  • Do you mean rename~/.mono/registry/CurrentUser/software/repetier? Do I just rename it repetier?
  • I just did this in ~/.mono/registry/CurrentUser/software
    $mv repetier repetier2
    $mv repetier2 repetier
    I then tried to run $repetierHost without sudo, got the same errors.
  • > Do you mean rename~/.mono/registry/CurrentUser/software/repetier? Do I just rename it repetier?
    yes that folder,
    second command undoes first so you get error back. So just rename it to repetier2 and starting host should create a new repetier folder.
  • edited October 2022
    OK, I see. I renamed it to repetier2 and started using repetierHost, starts and runs configuration queries for language, but a lot of the text shown is gibberish. Setting language and hitting OK starts RepetierHost, but the screen freezes and I can't do anything with it. It seems to be messing with screen graphics as it shows bits of my desktop too. The window title is Repetier-Host V2.2.4-tablet amf if that matters. I seem to get a hanging mono process that I have to kill from the command line, the window won't respond to clicking close.
    I get the following error in the console, but I got that when I was running under sudo:
    EDIT: Restarting with repetierHost in console seems to work on the second attempt. I am not sure why the initial setup launch was all screwed up, but it seems OK now.
