Problems after Update 1.4.1
After Update to 1.4.1:
Shutdown not possible, clicking the yes-button nothing happened. Switching off the pi is the only possibility to turn off.
Screensaver: 0 minutes means off, after a few minutes the screen is black.
Update was via wlan.
What will help? Download again and flash new?
  • How did you update? Autoupdate or new image - I ask because we have changed linux to bullseye image (from buster). But should not affect shutdown at all. Can you check server.log when you tried shutdown if you see an error in execution of the command.
