Klipper Installation friert ein "gcc-arm-none-eabi"
Preconditions:
-Raspberry Pi Zero 2, 32GB Speicher
-Repetier Server v1.4.1
-Wifi-Verbindung
Error-Path:
- Drucker Wizard gestartet
- Klipper als Firmware ausgewählt
- Installation von Klipper über "+ Installieren" Button gestartet
Error-Description:
- Freeze beim package install. Keine Recovery. Keine Änderung binnen stunden
--2022-07-26 11:25:58--  http://download1.repetier.com/files/server/extras/klipperInstaller.sh
Resolving download1.repetier.com (download1.repetier.com)... 94.130.164.39
Connecting to download1.repetier.com (download1.repetier.com)|94.130.164.39|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 5485 (5.4K) [application/octet-stream]
Saving to: '/tmp/klipperInstaller.sh'
/tmp/klipperInstaller. 100%[============================>]   5.36K  --.-KB/s    in 0s
2022-07-26 11:25:58 (96.5 MB/s) - '/tmp/klipperInstaller.sh' saved [5485/5485]
Install klipper with parameter: E617 tags/v0.10.0 1 https://github.com/Klipper3d/klipper.git
Shell: /bin/bash
###### Running apt-get update ######
Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.7 kB]
Get:3 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
Get:4 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [295 kB]
Hit:5 https://pkg.duet3d.com stable InRelease
Fetched 13.6 MB in 19s (710 kB/s)
Reading package lists... Done
###### Installing packages ######
Building dependency tree... Done
Reading state information... Done
Note, selecting 'python-dev-is-python2' instead of 'python-dev'
Note, selecting 'libusb-1.0-0-dev' for regex 'libusb-1.0'
Note, selecting 'libusb-1.0-doc' for regex 'libusb-1.0'
Note, selecting 'libusb-1.0-0' for regex 'libusb-1.0'
git is already the newest version (1:2.30.2-1).
libusb-1.0-0 is already the newest version (2:1.0.24-3).
libusb-1.0-0 set to manually installed.
The following additional packages will be installed:
  dpkg-dev fakeroot g++-10 gcc gcc-10 libalgorithm-diff-perl libalgorithm-diff-xs-perl
  libalgorithm-merge-perl libasan6 libcc1-0 libfakeroot libftdi1 libgcc-10-dev
  libhidapi-libusb0 libnewlib-dev libpython2-dev libpython2-stdlib libpython2.7
  libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib libstdc++-10-dev
  libstdc++-arm-none-eabi-newlib libubsan1 libusb-0.1-4 make python-is-python2 python2
  python2-dev python2-minimal python2.7 python2.7-dev python2.7-minimal python3-appdirs
  python3-distlib python3-filelock python3-importlib-metadata python3-more-itertools
  python3-virtualenv python3-zipp
Suggested packages:
  dfu-programmer avrdude-doc debian-keyring gcc-10-doc gcc-multilib autoconf automake
  libtool flex bison gcc-doc gcc-10-locales ncurses-doc libnewlib-doc libstdc++-10-doc
  make-doc python2-doc python-tk python2.7-doc binfmt-support
The following packages will be REMOVED:
  python-is-python3
The following NEW packages will be installed:
  avr-libc avrdude binutils-arm-none-eabi binutils-avr build-essential dfu-util dpkg-dev
  fakeroot g++ g++-10 gcc gcc-10 gcc-arm-none-eabi gcc-avr libalgorithm-diff-perl
  libalgorithm-diff-xs-perl libalgorithm-merge-perl libasan6 libcc1-0 libfakeroot
  libffi-dev libftdi1 libgcc-10-dev libhidapi-libusb0 libncurses-dev
  libnewlib-arm-none-eabi libnewlib-dev libpython2-dev libpython2-stdlib libpython2.7
  libstdc++-arm-none-eabi-newlib libubsan1 libusb-0.1-4 libusb-1.0-0-dev libusb-1.0-doc
  libusb-dev make python-dev-is-python2 python-is-python2 python2 python2-dev
  python3-virtualenv python3-zipp stm32flash virtualenv
0 upgraded, 58 newly installed, 1 to remove and 9 not upgraded.
Need to get 247 MB of archives.
After this operation, 2154 MB of additional disk space will be used.
Get:1 http://ftp.agdsn.de/pub/mirrors/raspbian/raspbian bullseye/main armhf libpython2.7-minimal armhf 2.7.18-8 [396 kB]
Get:2 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf python2.7-minimal armhf 2.7.18-8 [1076 kB]
Get:3 http://ftp.agdsn.de/pub/mirrors/raspbian/raspbian bullseye/main armhf python2-minimal armhf 2.7.18-3 [34.2 kB]
Get:5 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf python2.7 armhf 2.7.18-8 [311 kB]
Get:6 http://mirror.netcologne.de/raspbian/raspbian bullseye/main armhf libpython2-stdlib armhf 2.7.18-3 [21.2 kB]
Get:7 http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf python2 armhf 2.7.18-3 [24.5 kB]
Get:8 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf binutils-avr armhf 2.26.20160125+Atmel3.6.2-2 [1049 kB]
Get:9 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gcc-avr armhf 1:5.4.0+Atmel3.6.2-1 [12.4 MB]
Get:11 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libusb-0.1-4 armhf 2:0.1.12-32 [21.6 kB]
Get:13 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libhidapi-libusb0 armhf 0.10.1+dfsg-1 [13.0 kB]
Get:14 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf avrdude armhf 6.3-20171130+svn1429-2+b1 [283 kB]
Get:24 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf g++ armhf 4:10.2.1-1+rpi1 [1632 B]
Get:15 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf binutils-arm-none-eabi armhf 2.34-4+rpi1+14 [2121 kB]
Get:23 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf g++-10 armhf 10.2.1-6+rpi1 [7341 kB]
Get:16 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libcc1-0 armhf 10.2.1-6+rpi1 [38.3 kB]
Get:17 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libasan6 armhf 10.2.1-6+rpi1 [1986 kB]
Get:21 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gcc armhf 4:10.2.1-1+rpi1 [5196 B]
Get:22 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libstdc++-10-dev armhf 10.2.1-6+rpi1 [1751 kB]
Get:27 http://ftp.agdsn.de/pub/mirrors/raspbian/raspbian bullseye/main armhf build-essential armhf 12.9 [7704 B]
Get:25 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf make armhf 4.3-4.1 [376 kB]
Get:29 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf fakeroot armhf 1.25.3-1.1 [86.2 kB]
Get:30 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gcc-arm-none-eabi armhf 15:8-2019-q3-1+b1 [27.3 MB]
Get:36 http://ftp.agdsn.de/pub/mirrors/raspbian/raspbian bullseye/main armhf libnewlib-dev all 3.3.0-1 [262 kB]
Get:4 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian bullseye/main armhf libpython2.7-stdlib armhf 2.7.18-8 [1802 kB]
Get:10 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf avr-libc all 1:2.0.0+Atmel3.6.2-1.1 [4878 kB]
Get:31 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libalgorithm-diff-perl all 1.201-1 [43.3 kB]
Get:33 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libalgorithm-merge-perl all 0.08-3 [12.7 kB]
Get:28 http://mirror.pyratelan.org/raspbian/raspbian bullseye/main armhf libfakeroot armhf 1.25.3-1.1 [45.1 kB]
Get:12 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian bullseye/main armhf libftdi1 armhf 0.20-4 [17.0 kB]
Get:18 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libubsan1 armhf 10.2.1-6+rpi1 [746 kB]
Get:19 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libgcc-10-dev armhf 10.2.1-6+rpi1 [682 kB]
Get:20 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gcc-10 armhf 10.2.1-6+rpi1 [13.4 MB]
Get:26 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf dpkg-dev all 1.20.11+rpi1 [2308 kB]
Get:32 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libalgorithm-diff-xs-perl armhf 0.04-6+b1 [11.6 kB]
Get:37 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian bullseye/main armhf libnewlib-arm-none-eabi all 3.3.0-1 [34.6 MB]
Get:34 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libffi-dev armhf 3.3-6 [58.2 kB]
Get:35 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libncurses-dev armhf 6.2+20201114-2 [288 kB]
Get:38 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libpython2.7 armhf 2.7.18-8 [865 kB]
Get:39 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libpython2.7-dev armhf 2.7.18-8 [1967 kB]
Get:40 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libpython2-dev armhf 2.7.18-3 [21.3 kB]
Get:42 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libusb-1.0-0-dev armhf 2:1.0.24-3 [70.8 kB]
Get:43 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libusb-1.0-doc all 2:1.0.24-3 [192 kB]
Get:47 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python2-dev armhf 2.7.18-3 [1216 B]
Get:48 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python-dev-is-python2 all 2.7.18-9 [1528 B]
Get:49 http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf python3-appdirs all 1.4.4-1 [12.7 kB]
Get:45 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf python-is-python2 all 2.7.18-9 [2940 B]
Get:53 http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf python3-zipp all 1.0.0-3 [6060 B]
Get:46 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf python2.7-dev armhf 2.7.18-8 [292 kB]
Get:54 http://mirror.netcologne.de/raspbian/raspbian bullseye/main armhf python3-importlib-metadata all 1.6.0-2 [10.3 kB]
Get:50 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python3-distlib all 0.3.2+really+0.3.1-0.1 [123 kB]
Get:52 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf python3-more-itertools all 4.2.0-3 [42.7 kB]
Get:55 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python3-virtualenv all 20.4.0+ds-2+deb11u1 [89.1 kB]
Get:56 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf stm32flash armhf 0.5+git20200914+2b0f078-1 [21.0 kB]
Get:57 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf virtualenv all 20.4.0+ds-2+deb11u1 [21.4 kB]
Get:58 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf dfu-util armhf 0.9-1 [33.6 kB]
Get:41 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libstdc++-arm-none-eabi-newlib all 15:8-2019-q3-1+13 [127 MB]
Get:51 http://mirror.cxserv.de/raspbian bullseye/main armhf python3-filelock all 3.0.12-2 [8036 B]
Get:44 http://mirror.netzwerge.de/raspbian/raspbian bullseye/main armhf libusb-dev armhf 2:0.1.12-32 [35.7 kB]
Fetched 247 MB in 1min 18s (3171 kB/s)
Extracting templates from packages: 100%
(Reading database ... 97876 files and directories currently installed.)
Removing python-is-python3 (3.9.2-1) ...
Selecting previously unselected package libpython2.7-minimal:armhf.
(Reading database ... 97872 files and directories currently installed.)
Preparing to unpack .../0-libpython2.7-minimal_2.7.18-8_armhf.deb ...
Unpacking libpython2.7-minimal:armhf (2.7.18-8) ...
Selecting previously unselected package python2.7-minimal.
Preparing to unpack .../1-python2.7-minimal_2.7.18-8_armhf.deb ...
Unpacking python2.7-minimal (2.7.18-8) ...
Selecting previously unselected package python2-minimal.
Preparing to unpack .../2-python2-minimal_2.7.18-3_armhf.deb ...
Unpacking python2-minimal (2.7.18-3) ...
Selecting previously unselected package libpython2.7-stdlib:armhf.
Preparing to unpack .../3-libpython2.7-stdlib_2.7.18-8_armhf.deb ...
Unpacking libpython2.7-stdlib:armhf (2.7.18-8) ...
Selecting previously unselected package python2.7.
Preparing to unpack .../4-python2.7_2.7.18-8_armhf.deb ...
Unpacking python2.7 (2.7.18-8) ...
Selecting previously unselected package libpython2-stdlib:armhf.
Preparing to unpack .../5-libpython2-stdlib_2.7.18-3_armhf.deb ...
Unpacking libpython2-stdlib:armhf (2.7.18-3) ...
Setting up libpython2.7-minimal:armhf (2.7.18-8) ...
Setting up python2.7-minimal (2.7.18-8) ...
Linking and byte-compiling packages for runtime python2.7...
Setting up python2-minimal (2.7.18-3) ...
(Reading database ... 98618 files and directories currently installed.)
Preparing to unpack .../00-python2_2.7.18-3_armhf.deb ...
Unpacking python2 (2.7.18-3) ...
Selecting previously unselected package binutils-avr.
Preparing to unpack .../01-binutils-avr_2.26.20160125+Atmel3.6.2-2_armhf.deb ...
Unpacking binutils-avr (2.26.20160125+Atmel3.6.2-2) ...
Selecting previously unselected package gcc-avr.
Preparing to unpack .../02-gcc-avr_1%3a5.4.0+Atmel3.6.2-1_armhf.deb ...
Unpacking gcc-avr (1:5.4.0+Atmel3.6.2-1) ...
Selecting previously unselected package avr-libc.
Preparing to unpack .../03-avr-libc_1%3a2.0.0+Atmel3.6.2-1.1_all.deb ...
Unpacking avr-libc (1:2.0.0+Atmel3.6.2-1.1) ...
Selecting previously unselected package libusb-0.1-4:armhf.
Preparing to unpack .../04-libusb-0.1-4_2%3a0.1.12-32_armhf.deb ...
Unpacking libusb-0.1-4:armhf (2:0.1.12-32) ...
Selecting previously unselected package libftdi1:armhf.
Preparing to unpack .../05-libftdi1_0.20-4_armhf.deb ...
Unpacking libftdi1:armhf (0.20-4) ...
Selecting previously unselected package libhidapi-libusb0:armhf.
Preparing to unpack .../06-libhidapi-libusb0_0.10.1+dfsg-1_armhf.deb ...
Unpacking libhidapi-libusb0:armhf (0.10.1+dfsg-1) ...
Selecting previously unselected package avrdude.
Preparing to unpack .../07-avrdude_6.3-20171130+svn1429-2+b1_armhf.deb ...
Unpacking avrdude (6.3-20171130+svn1429-2+b1) ...
Selecting previously unselected package binutils-arm-none-eabi.
Preparing to unpack .../08-binutils-arm-none-eabi_2.34-4+rpi1+14_armhf.deb ...
Unpacking binutils-arm-none-eabi (2.34-4+rpi1+14) ...
Selecting previously unselected package libcc1-0:armhf.
Preparing to unpack .../09-libcc1-0_10.2.1-6+rpi1_armhf.deb ...
Unpacking libcc1-0:armhf (10.2.1-6+rpi1) ...
Selecting previously unselected package libasan6:armhf.
Preparing to unpack .../10-libasan6_10.2.1-6+rpi1_armhf.deb ...
Unpacking libasan6:armhf (10.2.1-6+rpi1) ...
Selecting previously unselected package libubsan1:armhf.
Preparing to unpack .../11-libubsan1_10.2.1-6+rpi1_armhf.deb ...
Unpacking libubsan1:armhf (10.2.1-6+rpi1) ...
Selecting previously unselected package libgcc-10-dev:armhf.
Preparing to unpack .../12-libgcc-10-dev_10.2.1-6+rpi1_armhf.deb ...
Unpacking libgcc-10-dev:armhf (10.2.1-6+rpi1) ...
Selecting previously unselected package gcc-10.
Preparing to unpack .../13-gcc-10_10.2.1-6+rpi1_armhf.deb ...
Unpacking gcc-10 (10.2.1-6+rpi1) ...
Selecting previously unselected package gcc.
Preparing to unpack .../14-gcc_4%3a10.2.1-1+rpi1_armhf.deb ...
Unpacking gcc (4:10.2.1-1+rpi1) ...
Selecting previously unselected package libstdc++-10-dev:armhf.
Preparing to unpack .../15-libstdc++-10-dev_10.2.1-6+rpi1_armhf.deb ...
Unpacking libstdc++-10-dev:armhf (10.2.1-6+rpi1) ...
Selecting previously unselected package g++-10.
Preparing to unpack .../16-g++-10_10.2.1-6+rpi1_armhf.deb ...
Unpacking g++-10 (10.2.1-6+rpi1) ...
Selecting previously unselected package g++.
Preparing to unpack .../17-g++_4%3a10.2.1-1+rpi1_armhf.deb ...
Unpacking g++ (4:10.2.1-1+rpi1) ...
Selecting previously unselected package make.
Preparing to unpack .../18-make_4.3-4.1_armhf.deb ...
Unpacking make (4.3-4.1) ...
Selecting previously unselected package dpkg-dev.
Preparing to unpack .../19-dpkg-dev_1.20.11+rpi1_all.deb ...
Unpacking dpkg-dev (1.20.11+rpi1) ...
Selecting previously unselected package build-essential.
Preparing to unpack .../20-build-essential_12.9_armhf.deb ...
Unpacking build-essential (12.9) ...
Selecting previously unselected package libfakeroot:armhf.
Preparing to unpack .../21-libfakeroot_1.25.3-1.1_armhf.deb ...
Unpacking libfakeroot:armhf (1.25.3-1.1) ...
Selecting previously unselected package fakeroot.
Preparing to unpack .../22-fakeroot_1.25.3-1.1_armhf.deb ...
Unpacking fakeroot (1.25.3-1.1) ...
Selecting previously unselected package gcc-arm-none-eabi.
Preparing to unpack .../23-gcc-arm-none-eabi_15%3a8-2019-q3-1+b1_armhf.deb ...
Unpacking gcc-arm-none-eabi (15:8-2019-q3-1+b1) ...
  • Stand beim Terminal in dem die Installation ablief "Terminal geschlossen" oben? Das hier ist ja noch entpacken/installieren von APT Packeten. Was ich vermute ist, dass die Verbinung zum pi kurz abgebrochen war und sich das Terminal damit geschlossen hat. Der Drucker existiert ja jetzt bereits nehme ich an wenn du die Startseite aufrufst. Einfach in den Drucker rein und im Klipper Fenster (im Druckermenu) noch mal starten und sehen ob er weiter kommt. Ich glaub nicht das da ein prinzipieller Fehler ist.
  • "Terminal geschlossen" wird nicht angezeigt. Wenn ich das Terminal schließe wird der nächste Schritt des Wizards angezeigt. Der Slug wird in der Portwahl auch angezeigt. Wenn ich das Dropdown Menü öffne kann ich allerdings den Port mit dem Slug nicht finden. Ebenfalls erhält der Server keine Antwort wenn ich trotzdem auf "Fortsetzen" klicke.
    Wenn ich den Drucker dann anwähle und in das Klipper-Fenster gehe bekomme ich lediglich ein komplett leeres Dropdown angezeigt. Auch die üblichen Buttons fehlen.
  • Übrigens lässt sich das Verhalten reproduzieren. Bei frischen Images passiert der Fehler immer an der selben Stelle.
  • Ok, sorry für die Verzögerung aber hatte viel zu tun und das ist etwas das doch viel Zeit braucht.
    Konnte jetzt auf einem Pi 3 mit neuem Image ähnliche Probleme erzeugen. Vorher hatte ich das auf einem pi 4 mit 8gb ram und schneller SD Karte getestet, da ging es Problemlos. Hier ist mir 2 mal Linux komplett abgestürzt.
    Hatte dabei top laufen und konnte sehen das die Last auf über 9 angestiegen war. Das besagte Paket scheint ein echter Klops für den Raspberry zu sein und ist über 600MB schwer. Hab dann testweise manuell in der ssh shell (nicht im server terminal)
    sudo apt install gcc-arm-none-eabi binutils-arm-none-eabi
    ausgeführt. Hat immerhin chrome zum Absturz gebracht aber ansonsten ging es weiter. Danach konnte ich im wizard endlich problemlos anlegen. Vermutlich hast du hier genau die gleichen Probleme bekommen wie ich mit dem riesen Paket. Da der installer aber ein debian Paket ist kann ich hier leider nichts ändern oder ich finde heraus was genau das Problem ist. Eigentlich hab ich ja keinen Speichermangel sehen können, aber einmal kam eine Fehlermeldung das ein pipe abgebrochen ist. Könnte also auch ein Problem mit der sd karte zu sein, das da etwas zu langsam weggeschrieben wird bis speicher voll läuft. Leider hat syslog den crash auch nicht überlebt und nichts schreiben können.
