Confused by configs
It may be fundimental point that I've missed, but, why are there configs for both Repetier host AND the slicing engine ?
Do I have to change both the Repetier host settings AND the slicing engine setting each time I change a nozzle size ?
  • The issue is that these are different softwares that are independent. Host just calls slicers.  But for gcode generation it is enough to only change the slicer config. Host number is more informational so you know  what is mounted.
