Reposition objects relative to center of object.
If I want to move an object 20mm to the right, I shouldn't have to do math based on the size of the object.
Also, there should be a "reposition object" button along with the scale, rotate and mirror in the top right.
Maybe reposition object button on the left could be based from the minX, minY co-ordinates and Top right relative movement.
  • Select the move object button left of the 3d view and select a object. Ten you get exact coordinates to enter. That's all we currently have.
    In the right obhect selection you can drag object onto each other to couple them to the same coordinate system. This is needed for multi extrusion objects to make them position correctly to each other,
