v1.3.0 is not possible to switch to Czech Language on PC access
After updating Linux Repetier Server to last version 1.3.0
is not possible from PC to switch web accessed interface to Czech Language.
Stays still in English language GUI. (Older 1.2.1 was working fine)
On real Raspberry PI with LCD installed is GUI OK set (Czech labeled)!
  • Arggh. I renamed language file from cz to cs as that would be more correct as it seems. But in
    INSTALL_DIR/languages is a file aliases.ini containing
    cs=cz
    if you delete that or replace it with
    cz=cs
    and restart server it should work. Will also be fixed on next release.
    cs=cz
    cz=cs
    I knew that! Thanks!
  • Thank You.
    Looking forward to new version.
