help withflashforge and repetier host
Hello,i need help,i tried every setting i could find I am using repetier host and trying to use it with an flashforge creator pro,
It shows to be connected  but i cannot print or use the manual controls.i have tried everything i could find but no luck.
Any suggestions  as to what I am missing or doing wrong?
  • Unfortunately, the Flashforge Creator Pro uses the sailfish firmware, which isn't supported.
    If you want to use Repetier Host, you may have to change your firmware.
  • So go for Sailfish. There were several who would use it and all are potential customers for Pro!
