adding support to .gcode model
i'm using an ender3 with creality slicing. have a model, "horse head", that has been sliced on repetier-host (cura) and does not have any support for overhanging portion of head. is it possible to add support using the creality slicer on the .gcode file.
  • Change in right side bar support type from None to Touching Bed or Everywhere and slice again. If it is configured good that should give you support.
