How to copy groups from one printer to another
Is there a way to copy groups from one printer to another? I have multiple printers that are the same, and would like to copy groups that I have uploaded onto one printer to another.
  • There is no direct solution.
    If they are on the same computer you can tell the other printers to use a different g-code directory and select the master printer.  That way the identical printers share same g-code data.
    If they are on different machines and you have configured exchanging projects, you can copy g-code to project on one machine and on the other inside project copy g-code to printer.
