Doesn't move in IDEX mode.
Trying out repetier for a few days.  Single Extruder print went well. Tried a dual extruder print, it warmed things up, but the when it started printing, nothing happened. It was updating as if it was printing, but no movement, no extrusion. stopped the print and printed directly from the usb stick into the printer so I know the file was good. (print came out well).
Same thing happened last time I tried a dual extruder print. single extruder seems to work, but not dual... what should I try next?
  • You should log the print and then see what is going on. E.g. did firmware tell host to stop/wait or is there a communication error, ... You can see only in the log what exactly is the issue here.
