Remote Touchscreen
I would like to know if it is possible to use a Raspberry Pi and a 7 inch touch screen to get the Repetier Touch interface in order to control a Repetier server installed on a windows machine.
Just an intial glance through the interface I saw an option to offload processing. Am I on the right track?
  • This touchscreen interface is supposed to only work over localhost. The only way you could connect to this interface is setting up a proxy on your windows machine.
