2 Repetier Pro on 2 different wifi
Hello, quick question: is it possible to connect 2 Repetier-Server Pro installations, that aren't connected to the same wifi, on the same Repetier Monitor?
Thx for the help
  • It depends. They must be both reachable from where the monitor runs. If there is no route it can not connect, but same wifi network is not necessary.
  • By reachable do you mean physical distance wise or? (kinda new to this lol)
  • No I mean network wise. E.g. if you ping the ip of both you should get a response from both.
