Timelapse snapshot quality.
No big deal, I was just wondering if there’s a way of improving the quality when using the “enforce position for snapshot” function. When the nozzle moves away from the print there’s a little stringing left on the print. Is there a way to eliminate ?
Many Thanks
  • Maybe. It uses these values to eliminate stringing:
    https://cln.sh/gWHWAg
    Especially retraction distance and retraction speed. These are used in slicer to reduce stringing and can be used for snapshots as well.
    I only get stringing on the snapshot move. How do I add the retraction settings to the snapshot ?
  • These values are only used for snapshot. Apart from that we assume them for timing computation if you use G10/G11 for retractions. So changing them is normally change. There are also event dependent gcodes before/after snapshot where you can add retractions/und retraction.
