Timelapse quality.
Heya, am I missing some setting somewhere to set the time lapse quality? I have it set to 1080p @ 30. Camera doesn't get better image than that anyway. When I either download it or play it back it is 240i or some bs. Very frustrated with this hole mess at the moment trying not to snap.
  • Sorry, setup info is a raspberry pi running 1.0.3 with a logitech c615 camera.
  • Conversion happens with same resolution as the images and these should match your webcam settings. So if you check the images or webcam is the quality ok.
    For conversion to mp4 the bitrate is relevant which might be too low for your resolution so increase that. Disable deleting images after conversion then you can experiment if it increases quality.
