light and dark modus
You mentioned, that You don't like shell commands in interfaces. That is quite acceptable (I'm programming myself), but what about reading a flag-file if it is present. For example my smart home software is generating files about sunset and sunrise with True and False in it. Could be used to control the light and dark modi more comfortable than switching by hand and leave the user the choice to automatically switch the modus of the background.
regards
jori
  • Don't forget the automatic mode! It will switch between light and dark mode depending on os dark mode. So when you set os to automatic it will also change the server ui.
