Does keyestudio 1602 controller work with repetier?
Would this smart controller work with repetier?
It looks almost identical to reprapdiscount 2004 controller so I would assume it wouldn't be too hard to set up
https://www.keyestudio.com/keyestudio-lcd1602-display-3d-module-with-sd-card-slot-30cm-cable-for-arduino-3d-printer-p0292.html
  • With some modifying of pins it might work but rather bad then good. Everything is optimized for 20x4 chars so with 2 lines menus are untested since years and it will not be fun. Also last 4 chars are often needed for full content so with only 16 chars in a row that is an additional limitation. So better don't try. Just more work to get it running and unsatisfying when it runs.
