Artillery SideWinder X1 Filament Switch
Hello,
is there any chance to get working the Filament Run-Out switch over Repetier Server?
It works fine if i print via USB but i need to get it working over the Server.
Thanks.
  • If it works same as for I3 mega it just does not send any information on trigger. In that case you would need to use a external filament sensor e.g. connected to pi.
