Problemi con codice attivazione
Ho acquistato la licenza, quando la inserisco mi da questo errore, che posso fare?
“Error communicating with license server: 400 400 means normally that the computer running the server can not reach the internet or resolve domain name. This is possible even of it is reachable in your intranet”
  • Translator doe snot detect this language!
    Often the problem is that the time on the computer is not set correctly or there is no internet connection even if the intranet connection is working.
    In case of linux you can see the computer time in the Bolt icon menu in the gui.
    I solve the problem, with Putty i change the date in raspberry forcing the syncronisiting of NTP
