Trouble using cura filament profiles in Repetier Host
Hello
 Im using Cura in Repetier Host 2.1.6   I finally switched to a new plastic and wanted to change the temperature by creating a new profile in Cura Filament settings. I created (and saved) the new profile, but it doesnt seem that it is being used. Only the default setting is used. So I can just change the default settings , but that defeats the purpose of having profiles. How do you select the new profile? How do you folks deal with switching plastics?  By the way I really love Repetier Host.
  • Did you after saving also switch the filament profile in the right tab - that decides which profile to use not what you have selected in the left side.
  • Ha Ha all these years and I  never saw that  Thank you!
