Dev2: Cleanup of configuration.h
In the configuration.h I do find:
#define BEEPER_SHORT_SEQUENCE 2, 2
#define BEEPER_LONG_SEQUENCE 8, 8
#define UI_SET_MIN_HEATED_BED_TEMP 20
#define UI_SET_MIN_EXTRUDER_TEMP 80
#define UI_SET_MAX_EXTRUDER_TEMP 275
#define UI_SET_EXTRUDER_FEEDRATE 5
//#define CUSTOM_EVENTS
//#define CUSTOM_MENU
//#define CUSTOM_TRANSLATIONS
#define HALFAUTOMATIC_LEVELING 1
// add z probe height routine
//#define ZPROBE_HEIGHT_ROUTINE
//#define ZPROBE_REF_HEIGHT 5.97
//#define Z_UP_AFTER_HOME 0
#endif
Because I cannot find any of them in other files (using the "search in files"-function of visual studio code), I think all of these lines can be deleted. Or am I wrong?
