not able to print
edited September 2020 in Repetier-Server
i am having a German RepRap x 350 pro printer, i am able to set all the parameters including extruder temp, bed temp, and able to upload the sliced g code processed in simplify 3d slicer to the server but when i try to print the same it does not print.when i press the print button nothing seems to work in my 3d printer. Some one please help me sort out the issue.
  • Activate logging and see what it contains for the started print. I assume server is starting print and it is just not happening what you expect?
