Separate controls for extrusion multiplier in custom plugin
Hi! I made a custom plugin for Repetier-Host to control a dual extrusion printer that work with pastes. In the plugin that I made, there are two knobs that control the extrusion multiplier, one for each extruder. I'd like to know if there's a way to, after the printing has started with the RunJob() method, identify when the Host sends a "change tool" command such as "T0" and inject the command for the extrusion multiplier. In other words, is there a way to know which line has been sent (a way to my plugin read the Log, for instance) and use host.Connection.injectManualCommand(); when it sees a change tool gcode?
  • The gcode analyser has a event
     public event OnAnalyzerChange eventChange;
    that gets called when the extruder has changed. It also gets called on other occasions so check if it is a tool change why it was called. Target handler gets no parameter.
    You get the analyser from the printerconnector instance
           GCodeAnalyzer Analyzer
                get;
    This is hopefully fast enough to inject it for next line. Will not work when printing over repetier-server since then the server controls the sending process.
