"Pause and Resume" Printer with Light Sensor Data
Hello!
I am pretty new to messing around with 3d printers, but that's what I need to do... So please help me out here!
I am working on a project where I control a 3d printer with Repetier-Host connected through a USB and what I need to do is sending commands to pause and resume a printer based on sensor data I get real-time from a light-meter.
For example, I use a light sensor that reads Lux value real-time and if the number goes below 10,000, pause the printer and resume the printer when it goes back up 10,000.
I currently read the sensor from the light-meter and pause/resume the printer manually through Repetier.
I would like to automate this part by calling a command based on input data from the light-meter.
I am logging/reading Lux on my computer and the printer is connected to the same computer through Repetier-Host.
Please let me know if you have any suggestions to implement the system through Repetier (Or any other methods).
Any advice would be appreciated.
Thanks!
  • WIth host the only solution is writing a plugin. Only our repetier-server has a web api to change states remotely as described in the othe rthread.
