Auto Leveling Crashes Print Head at Third Sample Spot
When doing a nine point auto leveling at the start of a print the print head crashes into the bed after successfully sampling the first two spots. I use Repetier firmware and host on a Tronxy P802MA.
I'm using G28; home all axes (works fine)
Followed by G29; auto level (samples first 2 of 9 spots fine, then drives head into bed at third spot until I hit emergency stop.)
This started after I tried printing from an sd card for the first time (unsuccessfully). I've had no problems printing via usb up to now. I don't need to use the sd card, so I'm trying to get back to using the usb as I did before.
This seems like a software problem. Any suggestions?
  • I solved the problem on my own by sending the following to correct the corrupted eeprom:
    M502 ; Load values from configuration.h
    M500 ; store values to eeprom
    Hope this helps someone else.
  • G29 is a marlin code for bed levelling.
    Repetier firmware uses G32 for bed levelling or G33 for mesh levelling
  • I am having the same problem with my nozzle crashing into the bed on the third sampling when performing and auto leveling function like G32 or even G30 with 3 repetitions. The first 2 touches to the bed work perfectly but the third touch it disregards the z-probe and drives the nozzle into the bed.  I had this issue with a microswitch that I used to attempt making my nozzle a z-probe.  I assumed the issue was just my own poor design.  So I am now using a BLTouch v3.1 and I am having the same issue.  I am currently using repetier firmware 1.0.4.  Issue also happens with current development version of 1.0.5dev.  I have a ramps 1.4/ Mega 2560 on a Rostock Delta.  I tried the M502 and M500 to clear my EEPROM.  I assume that this is probably just some small setting that I am missing.  This is the first time I have ever posted.    I am in desperate need of help on this one.  I cannot figure it out.  Thank you in advance for any help you can give!
    Here is my current Configuration.h
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       This file is optimized for version 1.0.4dev
       as you expect.
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 33
    #include "pins.h"
    #define HOST_RESCUE 1
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    #undef X_MIN_PIN
    #define X_MIN_PIN -1
    #undef Y_MIN_PIN
    #define Y_MIN_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 3
    #define XAXIS_STEPS_PER_MM 80
    #define YAXIS_STEPS_PER_MM 80
    #define ZAXIS_STEPS_PER_MM 80
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 370
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_EXTRUDER_COOLER_PIN HEATER_2_PIN
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 450
    #define GENERIC_THERM_VREF 5
    #define TEMP_GAIN 0
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_TYPE 8
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 285
    #define MIN_DEFECT_TEMPERATURE 10
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 5
    #define ENDSTOP_X_BACK_ON_HOME 3
    #define ENDSTOP_Y_BACK_ON_HOME 3
    #define ENDSTOP_Z_BACK_ON_HOME 3
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR 1
    #define Y_HOME_DIR 1
    #define Z_HOME_DIR 1
    #define X_MAX_LENGTH 588.4
    #define Y_MAX_LENGTH 588.4
    #define Z_MAX_LENGTH 510.7
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 0
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_DIAGONAL_ROD 252 // mm
    #define DELTA_ALPHA_A 210
    #define DELTA_ALPHA_B 330
    #define DELTA_ALPHA_C 90
    #define DELTA_MAX_RADIUS 150
    #define ROD_RADIUS 122.7
    #define PRINTER_RADIUS 122.7
    #define DELTA_HOME_ON_POWER 0
    #define STEP_COUNTER
    //#define SOFTWARE_LEVELING
    #define DELTASEGMENTS_PER_PRINTLINE 23
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 200
    #define HOMING_FEEDRATE_X 30
    #define HOMING_FEEDRATE_Y 90
    #define HOMING_FEEDRATE_Z 20
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_PRE_RAISE_DISTANCE 5
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define DOUBLE_STEP_DELAY 1 // time in microseconds
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1000
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1000
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    #define FEATURE_SERVO 1
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 1
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 60
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_SWITCHING_DISTANCE 10
    #define Z_PROBE_REPETITIONS 3
    #define Z_PROBE_USE_MEDIAN 0
    #define Z_PROBE_HEIGHT 4
    #define Z_PROBE_DELAY 100
    #define Z_PROBE_START_SCRIPT "M340 P0 S647"
    #define Z_PROBE_FINISHED_SCRIPT "M340 P0 S1473"
    #define Z_PROBE_RUN_AFTER_EVERY_PROBE "M340 P0 S2194"
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 -60
    #define Z_PROBE_Y1 -60
    #define Z_PROBE_X2 60
    #define Z_PROBE_Y2 -60
    #define Z_PROBE_X3 -60
    #define Z_PROBE_Y3 60
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #undef SDCARDDETECTINVERTED
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 10
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define LANGUAGE_RU_ACTIVE 0
    #define UI_PRINTER_NAME "Rostock Tall"
    #define UI_PRINTER_COMPANY "Roy Matlack"
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_MIN_EXTRUDER_TEMP   180
    #define UI_SET_MAX_EXTRUDER_TEMP   240
    #define NUM_MOTOR_DRIVERS 0
        "editMode": 2,
        "processor": 0,
        "baudrate": 115200,
        "bluetoothSerial": -1,
        "bluetoothBaudrate": 115200,
        "xStepsPerMM": 80,
        "yStepsPerMM": 80,
        "zStepsPerMM": 80,
        "xInvert": "0",
        "x2Invert": 0,
        "xInvertEnable": 0,
        "eepromMode": 1,
        "yInvert": "0",
        "y2Invert": 0,
        "yInvertEnable": 0,
        "zInvert": "0",
        "z2Invert": 0,
        "z3Invert": 0,
        "z4Invert": 0,
        "zInvertEnable": 0,
        "extruder": [
                "id": 0,
                "heatManager": 3,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 8,
                "sensorPin": "TEMP_0_PIN",
                "heaterPin": "HEATER_0_PIN",
                "maxFeedrate": 50,
                "startFeedrate": 20,
                "invert": "0",
                "invertEnable": "0",
                "acceleration": 5000,
                "watchPeriod": 1,
                "pidP": 7,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetractTemp": 150,
                "waitRetractUnits": 0,
                "waitRetract": 0,
                "stepsPerMM": 370,
                "coolerPin": "HEATER_2_PIN",
                "coolerSpeed": 255,
                "selectCommands": "",
                "deselectCommands": "",
                "xOffset": 0,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 0",
                    "step": "ORIG_E0_STEP_PIN",
                    "dir": "ORIG_E0_DIR_PIN",
                "advanceBacklashSteps": 0,
                "decoupleTestPeriod": 12,
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "preheat": 190,
                "inverse": 0
        "uiLanguage": 0,
        "uiController": 0,
        "xMinEndstop": 0,
        "yMinEndstop": 0,
        "zMinEndstop": 4,
        "xMaxEndstop": 2,
        "yMaxEndstop": 2,
        "zMaxEndstop": 2,
        "x2MinEndstop": 0,
        "y2MinEndstop": 0,
        "x2MaxEndstop": 0,
        "y2MaxEndstop": 0,
        "motherboard": 33,
        "driveSystem": 3,
        "xMaxSpeed": 200,
        "xHomingSpeed": 30,
        "xTravelAcceleration": 1000,
        "xPrintAcceleration": 1000,
        "yMaxSpeed": 200,
        "yHomingSpeed": 90,
        "yTravelAcceleration": 1000,
        "yPrintAcceleration": 1000,
        "zMaxSpeed": 200,
        "zHomingSpeed": 20,
        "zTravelAcceleration": 1000,
        "zPrintAcceleration": 1000,
        "xMotor": {
            "name": "X motor",
            "step": "ORIG_X_STEP_PIN",
            "dir": "ORIG_X_DIR_PIN",
            "enable": "ORIG_X_ENABLE_PIN"
        "yMotor": {
            "name": "Y motor",
            "step": "ORIG_Y_STEP_PIN",
            "dir": "ORIG_Y_DIR_PIN",
            "enable": "ORIG_Y_ENABLE_PIN"
        "zMotor": {
            "name": "Z motor",
            "step": "ORIG_Z_STEP_PIN",
            "dir": "ORIG_Z_DIR_PIN",
            "enable": "ORIG_Z_ENABLE_PIN"
        "enableBacklash": "0",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "stepperInactiveTime": 360,
        "maxInactiveTime": 0,
        "xMinPos": 0,
        "yMinPos": 0,
        "zMinPos": 0,
        "xLength": 588.4,
        "yLength": 588.4,
        "zLength": 510.7,
        "alwaysCheckEndstops": "0",
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": "1",
        "yHomeDir": "1",
        "zHomeDir": 1,
        "xEndstopBack": 3,
        "yEndstopBack": 3,
        "zEndstopBack": 3,
        "deltaDiagonalRod": 252,
        "deltaHorizontalRadius": 122.7,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "deltaAlphaC": 90,
        "deltaDiagonalCorrA": 0,
        "deltaDiagonalCorrB": 0,
        "deltaDiagonalCorrC": 0,
        "deltaMaxRadius": 150,
        "deltaRadiusCorrA": 0,
        "deltaRadiusCorrB": 0,
        "deltaRadiusCorrC": 0,
        "deltaXOffsetSteps": 0,
        "deltaYOffsetSteps": 0,
        "deltaZOffsetSteps": 0,
        "deltaSegmentsPerLine": 23,
        "stepperHighDelay": 0,
        "directionDelay": 0,
        "allowQuadstepping": "1",
        "doubleStepDelay": 1,
        "maxJerk": 20,
        "maxZJerk": 0.3,
        "moveCacheSize": 16,
        "moveCacheLow": 10,
        "lowTicksPerMove": 250000,
        "enablePowerOnStartup": "1",
        "echoOnExecute": "1",
        "sendWaits": "1",
        "ackWithLineNumber": "1",
        "killMethod": 1,
        "useAdvance": "0",
        "useQuadraticAdvance": "0",
        "powerInverting": 0,
        "mirrorX": 0,
        "mirrorXMotor": {
            "name": "Extruder 1",
            "step": "ORIG_E1_STEP_PIN",
            "dir": "ORIG_E1_DIR_PIN",
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": 0,
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
            "name": "Extruder 2",
            "step": "ORIG_E2_STEP_PIN",
            "dir": "ORIG_E2_DIR_PIN",
        "mirrorZ4": "0",
        "mirrorZ4Motor": {
            "name": "Extruder 3",
            "step": "ORIG_E3_STEP_PIN",
            "dir": "ORIG_E3_DIR_PIN",
        "dittoPrinting": "0",
        "featureServos": "1",
        "servo0Pin": 11,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "featureWatchdog": "0",
        "hasHeatedBed": "1",
        "enableZProbing": "1",
        "extrudeMaxLength": 450,
        "featureController": 10,
        "uiPrinterName": "Rostock Tall",
        "uiPrinterCompany": "Roy Matlack",
        "uiPagesDuration": 4000,
        "uiHeadline": "",
        "uiDisablePageswitch": "1",
        "uiAutoReturnAfter": 30000,
        "featureKeys": "0",
        "uiEncoderSpeed": 1,
        "uiReverseEncoder": "0",
        "uiKeyBouncetime": 10,
        "uiKeyFirstRepeat": 500,
        "uiKeyReduceRepeat": 50,
        "uiKeyMinRepeat": 50,
        "featureBeeper": "0",
        "uiMinHeatedBed": 30,
        "uiMaxHeatedBed": 120,
        "uiMinEtxruderTemp": 180,
        "uiMaxExtruderTemp": 240,
        "uiExtruderFeedrate": 2,
        "maxBedTemperature": 120,
        "bedSensorType": 8,
        "bedSensorPin": "TEMP_1_PIN",
        "bedHeatManager": 0,
        "bedPreheat": 55,
        "bedUpdateInterval": 5000,
        "bedPidDriveMin": 80,
        "bedPidDriveMax": 255,
        "bedPidP": 196,
        "bedPidI": 33,
        "bedPidD": 290,
        "bedPidMax": 255,
        "bedDecoupleTestPeriod": 300,
        "caseLightPin": -1,
        "caseLightDefaultOn": "1",
        "bedSkipIfWithin": 3,
        "gen1T0": 25,
        "gen1R0": 100000,
        "gen1Beta": 4036,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 0,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "tempHysteresis": 0,
        "pidControlRange": 20,
        "skipM109Within": 2,
        "extruderFanCoolTemp": 50,
        "minTemp": 150,
        "maxTemp": 285,
        "minDefectTemp": 10,
        "maxDefectTemp": 290,
        "arcSupport": "1",
        "forceChecksum": "0",
        "sdExtendedDir": "1",
        "featureFanControl": "1",
        "fanPin": "ORIG_FAN_PIN",
        "featureFan2Control": "0",
        "fan2Pin": "ORIG_FAN2_PIN",
        "fanThermoPin": -1,
        "fanThermoMinPWM": 128,
        "fanThermoMaxPWM": 255,
        "fanThermoMinTemp": 45,
        "fanThermoMaxTemp": 60,
        "fanThermoThermistorPin": -1,
        "fanThermoThermistorType": 1,
        "scalePidToMax": 0,
        "zProbeBedDistance": 10,
        "zProbeDisableHeaters": "0",
        "zProbePullup": "0",
        "zProbeOnHigh": "1",
        "zProbeXOffset": 0,
        "zProbeYOffset": 0,
        "zProbeWaitBeforeTest": "0",
        "zProbeSpeed": 60,
        "zProbeXYSpeed": 150,
        "zProbeHeight": 4,
        "zProbeStartScript": "M340 P0 S647",
        "zProbeFinishedScript": "M340 P0 S1473",
        "featureAutolevel": "1",
        "zProbeX1": -60,
        "zProbeY1": -60,
        "zProbeX2": 60,
        "zProbeY2": -60,
        "zProbeX3": -60,
        "zProbeY3": 60,
        "zProbeSwitchingDistance": 10,
        "zProbeRepetitions": 3,
        "zProbeMedian": "0",
        "zProbeEveryPoint": "M340 P0 S2194",
        "sdSupport": "1",
        "sdCardDetectPin": -1,
        "sdCardDetectInverted": "0",
        "uiStartScreenDelay": 1000,
        "xEndstopBackMove": 5,
        "yEndstopBackMove": 5,
        "zEndstopBackMove": 5,
        "xEndstopRetestFactor": 3,
        "yEndstopRetestFactor": 3,
        "zEndstopRetestFactor": 3,
        "xMinPin": -1,
        "yMinPin": -1,
        "zMinPin": "ORIG_Z_MIN_PIN",
        "xMaxPin": "ORIG_X_MAX_PIN",
        "yMaxPin": "ORIG_Y_MAX_PIN",
        "zMaxPin": "ORIG_Z_MAX_PIN",
        "x2MinPin": -1,
        "y2MinPin": -1,
        "x2MaxPin": -1,
        "y2MaxPin": -1,
        "deltaHomeOnPower": "0",
        "fanBoardPin": -1,
        "heaterPWMSpeed": 0,
        "featureBabystepping": "1",
        "babystepMultiplicator": 1,
        "pdmForHeater": "0",
        "pdmForCooler": "0",
        "psOn": "ORIG_PS_ON_PIN",
        "mixingExtruder": "0",
        "featureAxisComp": "0",
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "retractOnPause": 2,
        "pauseStartCommands": "",
        "pauseEndCommands": "",
        "distortionCorrection": "1",
        "distortionCorrectionR": 100,
        "distortionPermanent": "1",
        "distortionEndDegrade": 1,
        "distortionXMin": 10,
        "distortionXMax": 190,
        "distortionYMin": 10,
        "distortionYMax": 190,
        "sdRunOnStop": "",
        "featureRetraction": "1",
        "autoretractEnabled": "0",
        "retractionLength": 3,
        "retractionLongLength": 13,
        "retractionSpeed": 40,
        "retractionZLift": 0,
        "retractionUndoSpeed": 20,
        "filamentChangeXPos": 0,
        "filamentChangeYPos": 0,
        "filamentChangeZAdd": 2,
        "filamentChangeRehome": 1,
        "fanKickstart": 200,
        "servo0StartPos": -1,
        "servo1StartPos": -1,
        "servo2StartPos": -1,
        "servo3StartPos": -1,
        "uiDynamicEncoderSpeed": "1",
        "uiServoControl": 0,
        "killIfSensorDefect": "0",
        "jamSteps": 220,
        "jamSlowdownSteps": 320,
        "jamSlowdownTo": 70,
        "jamErrorSteps": 500,
        "jamMinSteps": 10,
        "jamAction": 1,
        "jamMethod": 1,
        "primaryPort": 0,
        "numMotorDrivers": 0,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "invertDirection": "0",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "invertEndstop": "0",
                "minEndstop": "1",
                "endstopPullup": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
        "manualConfig": "",
        "zHomeMinTemperature": 0,
        "zHomeXPos": 999999,
        "zHomeYPos": 999999,
        "zHomeHeatHeight": 20,
        "zHomeHeatAll": "1",
        "zProbeZOffsetMode": 0,
        "zProbeZOffset": 0,
        "zProbeDelay": 100,
        "uiBedCoating": "1",
        "langEN": "1",
        "langDE": "0",
        "langNL": "0",
        "langPT": "0",
        "langIT": "0",
        "langES": "0",
        "langFI": "0",
        "langSE": "0",
        "langFR": "0",
        "langCZ": "0",
        "langPL": "0",
        "langTR": "0",
        "langRU": "0",
        "accelerationFactorTop": 100,
        "bendingCorrectionA": 0,
        "bendingCorrectionB": 0,
        "bendingCorrectionC": 0,
        "supportLaser": "0",
        "laserPin": -1,
        "laserOnHigh": "1",
        "laserWarmupTime": 0,
        "defaultPrinterMode": 0,
        "laserPwmMax": 255,
        "laserWatt": 2,
        "supportCNC": "0",
        "cncWaitOnEnable": 300,
        "cncWaitOnDisable": 0,
        "cncEnablePin": -1,
        "cncEnableWith": "1",
        "cncDirectionPin": -1,
        "cncDirectionCW": "1",
        "cncPwmMax": 255,
        "cncRpmMax": 8000,
        "cncSafeZ": 150,
        "startupGCode": "",
        "jsonOutput": "0",
        "bedLevelingMethod": 0,
        "bedCorrectionMethod": 0,
        "bedLevelingGridSize": 5,
        "bedLevelingRepetitions": 5,
        "bedMotor1X": 0,
        "bedMotor1Y": 0,
        "bedMotor2X": 200,
        "bedMotor2Y": 0,
        "bedMotor3X": 100,
        "bedMotor3Y": 200,
        "zProbeRequiresHeating": "0",
        "zProbeMinTemperature": 150,
        "adcKeypadPin": -1,
        "sharedExtruderHeater": "0",
        "extruderSwitchXYSpeed": 100,
        "dualXAxis": "0",
        "boardFanSpeed": 255,
        "keepAliveInterval": 2000,
        "moveXWhenHomed": "0",
        "moveYWhenHomed": "0",
        "moveZWhenHomed": "0",
        "preheatTime": 30000,
        "multiZEndstopHoming": "0",
        "z2MinMaxPin": -1,
        "z2MinMaxEndstop": 0,
        "extruderIsZProbe": "0",
        "boardFanMinSpeed": 0,
        "doorPin": -1,
        "doorEndstop": 1,
        "zhomePreRaise": 0,
        "zhomePreRaiseDistance": 5,
        "dualXResolution": "0",
        "x2axisStepsPerMM": 100,
        "coolerPWMSpeed": 0,
        "maxFanPWM": 255,
        "raiseZOnToolchange": 0,
        "distortionLimitTo": 2,
        "automaticPowerup": 0,
        "hasTMC2130": "0",
        "TMC2130Sensorless": "0",
        "TMC2130Steathchop": "1",
        "TMC2130Interpolate256": "1",
        "TMC2130PWMAmpl": 255,
        "TMC2130PWMGrad": 1,
        "TMC2130PWMAutoscale": "1",
        "TMC2130PWMFreq": 2,
        "TMC2130CSX": -1,
        "TMC2130CSY": -1,
        "TMC2130CSZ": -1,
        "TMC2130CSE0": -1,
        "TMC2130CSE1": -1,
        "TMC2130CSE2": -1,
        "TMC2130CSE3": -1,
        "TMC2130CSE4": -1,
        "TMC2130CurrentX": 1000,
        "TMC2130CurrentY": 1000,
        "TMC2130CurrentZ": 1000,
        "TMC2130CurrentE0": 1000,
        "TMC2130CurrentE1": 1000,
        "TMC2130CurrentE2": 1000,
        "TMC2130CurrentE3": 1000,
        "TMC2130CurrentE4": 1000,
        "microstepX": 16,
        "microstepY": 16,
        "microstepZ": 16,
        "microstepE0": 16,
        "microstepE1": 16,
        "microstepE2": 16,
        "microstepE3": 16,
        "microstepE4": 16,
        "parkPosX": 0,
        "parkPosY": 0,
        "parkPosZ": 10,
        "emergencyParser": -1,
        "hostRescue": "1",
        "MAX31855SwCS": -1,
        "MAX31855SwCLK": -1,
        "tempGain": "0",
        "maxHalfstepInterval": 1999,
        "uiAnimation": "1",
        "uiPresetBedTempPLA": 55,
        "uiPresetBedABS": 120,
        "uiPresetExtruderPLA": 185,
        "uiPresetExtruderABS": 230,
        "hasMAX6675": false,
        "hasMAX31855": false,
        "hasGeneric1": false,
        "hasGeneric2": false,
        "hasGeneric3": false,
        "hasUser0": false,
        "hasUser1": false,
        "hasUser2": false,
        "numExtruder": 1,
        "version": 100.4,
        "primaryPortName": "",
        "hasMAX31855SW": false
  • I see you have not defined an offset for the z probe which is most likely not correct but not the problem. Except you have set a big one in eeprom.
    From what I see it should have tested -60/60 as thirs point.
    Can you post a log of the leveing so we see what printer was doing/trying and make comments on difference to what is says and what it does.
  • Thank you for your help on this!
    First a bit more information on my hardware. My Mega 2560 is connected via USB to and is powered by my Raspberry PI Zero/W running Repetier Server 0.94.2.   My RAMPS 1.4 is connected separately
    Here is what I did during the logs.
    I plugged in the power supply.
    G32
    First two touches went well and the third touch did not stop as we expected in this issue.
    I pulled the power power to the power supply to stop the nozzle crash and then plugged it back in.
    I clicked Home.
    G30
    I pulled the power power to the power supply to stop the nozzle crash.
    Here are the logs from that time.
     19:11:49.963 : wait
    19:11:49.965 : T:20.00 /0 B:21.22 /0 B@:0 @:0
    19:11:50.944 : wait
    19:11:51.057 : T:19.82 /0 B:21.34 /0 B@:0 @:0
    19:11:51.455 : g32
    19:11:51.494 : Slow command added:g32
    19:11:51.494 : ok 30
    19:11:51.494 : Z correction disabled
    19:11:52.154 : T:20.00 /0 B:21.34 /0 B@:0 @:0
    19:11:53.257 : T:20.12 /0 B:21.34 /0 B@:0 @:0
    19:11:53.584 : busy:processing
    19:11:54.348 : T:20.00 /0 B:21.46 /0 B@:0 @:0
    19:11:55.448 : T:19.30 /0 B:20.98 /0 B@:0 @:0
    19:11:55.564 : busy:processing
    19:11:56.535 : T:20.24 /0 B:21.83 /0 B@:0 @:0
    19:11:57.518 : T:20.12 /0 B:21.59 /0 B@:0 @:0
    19:11:57.518 : busy:processing
    19:11:58.057 : Dtr: false Rts: false
    19:11:59.099 : Dtr: false Rts: false
    19:11:59.099 : Connection started
    19:11:59.927 : start
    19:11:59.927 : Info:External Reset
    19:11:59.927 : Detected EEPROM version:20
    19:11:59.927 : Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
    19:12:01.235 : zDistortionCorrection:0
    19:12:01.235 : Free RAM:971
    19:12:01.363 : Card successfully initialized.
    19:12:01.363 : Autoretract:0
    19:12:01.363 : X:0.00 Y:0.00 Z:0.000 E:0.0000
    19:12:01.363 : SelectExtruder:0
    19:12:01.364 : FlowMultiply:100
    19:12:01.364 : ok
    19:12:01.364 : ok 1
    19:12:01.364 : DebugLevel:6
    19:12:01.364 : info:Continue from fatal state
    19:12:01.364 : ok
    19:12:01.364 : ok 2
    19:12:01.366 : T:19.47 /0 B:20.98 /0 B@:0 @:0
    19:12:01.366 : ok 3
    19:12:01.366 : FIRMWARE_NAME:Repetier_1.0.4 COMPILED:Aug 22 2020 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
    19:12:01.366 : Cap:PROGRESS:1
    19:12:01.366 : M155 S1
    19:12:01.366 : Cap:AUTOREPORT_TEMP:1
    19:12:01.517 : Cap:HOST_RESCUE:1
    19:12:01.517 : Cap:EEPROM:1
    19:12:01.517 : Cap:AUTOLEVEL:1
    19:12:01.517 : Cap:Z_PROBE:1
    19:12:01.517 : Cap:SOFTWARE_POWER:1
    19:12:01.517 : Cap:TOGGLE_LIGHTS:0
    19:12:01.517 : Cap:PAUSESTOP:1
    19:12:01.517 : Cap:PREHEAT:1
    19:12:01.517 : Cap:EMERGENCY_PARSER:0
    19:12:01.517 : Printed filament:8306.03m Printing time:55 days 10 hours 26 min
    19:12:01.517 : PrinterMode:FFF
    19:12:01.517 : ok 4
    19:12:01.518 : SpeedMultiply:100
    19:12:01.518 : ok 5
    19:12:01.518 : FlowMultiply:100
    19:12:01.518 : ok 6
    19:12:01.518 : Info:No case lights
    19:12:01.518 : ok 7
    19:12:01.518 : ok 8
    19:12:01.518 : ok 9
    19:12:01.518 : ok 10
    19:12:01.518 : ok 11
    19:12:01.518 : X:0.00 Y:0.00 Z:0.000 E:0.0000
    19:12:01.518 : ok 12
    19:12:01.518 : DebugLevel:6
    19:12:01.518 : ok 13
    19:12:01.518 : Config:Baudrate:115200
    19:12:01.518 : Config:InputBuffer:127
    19:12:01.519 : Config:NumExtruder:1
    19:12:01.519 : Config:MixingExtruder:0
    19:12:01.519 : Config:HeatedBed:1
    19:12:01.519 : Config:SDCard:1
    19:12:01.519 : Config:Fan:1
    19:12:01.519 : Config:Fan2:0
    19:12:01.519 : Config:LCD:1
    19:12:01.519 : Config:SoftwarePowerSwitch:1
    19:12:01.519 : Config:XHomeDir:1
    19:12:01.519 : Config:YHomeDir:1
    19:12:01.519 : Config:ZHomeDir:1
    19:12:01.519 : Config:XHomePos:0.00
    19:12:01.519 : Config:YHomePos:0.00
    19:12:01.519 : Config:ZHomePos:510.700
    19:12:01.519 : Config:SupportG10G11:1
    19:12:01.519 : Config:SupportLocalFilamentchange:1
    19:12:01.653 : Config:CaseLights:0
    19:12:01.653 : Config:ZProbe:1
    19:12:01.653 : Config:Autolevel:1
    19:12:01.653 : Config:EEPROM:1
    19:12:01.653 : Config:PrintlineCache:16
    19:12:01.653 : Config:JerkXY:20.00
    19:12:01.653 : Config:KeepAliveInterval:2000
    19:12:01.653 : Config:RetractionLength:3.00
    19:12:01.653 : Config:RetractionLongLength:13.00
    19:12:01.654 : Config:RetractionSpeed:40.00
    19:12:01.654 : Config:RetractionZLift:0.00
    19:12:01.654 : Config:RetractionUndoExtraLength:0.00
    19:12:01.654 : Config:RetractionUndoExtraLongLength:0.00
    19:12:01.654 : Config:RetractionUndoSpeed:20.00
    19:12:01.654 : Config:XMin:0.00
    19:12:01.654 : Config:YMin:0.00
    19:12:01.654 : Config:ZMin:0.00
    19:12:01.654 : Config:XMax:588.40
    19:12:01.654 : Config:YMax:588.40
    19:12:01.654 : Config:ZMax:510.70
    19:12:01.654 : Config:XSize:588.40
    19:12:01.654 : Config:YSize:588.40
    19:12:01.654 : Config:ZSize:510.70
    19:12:01.654 : Config:XPrintAccel:1000.00
    19:12:01.654 : Config:YPrintAccel:1000.00
    19:12:01.654 : Config:ZPrintAccel:1000.00
    19:12:01.654 : Config:XTravelAccel:1000.00
    19:12:01.654 : Config:YTravelAccel:1000.00
    19:12:01.654 : Config:ZTravelAccel:1000.00
    19:12:01.654 : Config:PrinterType:Delta
    19:12:01.654 : Config:MaxBedTemp:120
    19:12:01.655 : Config:Extr.1:Jerk:20.00
    19:12:01.655 : Config:Extr.1:MaxSpeed:50.00
    19:12:01.655 : Config:Extr.1:Acceleration:5000.00
    19:12:01.655 : Config:Extr.1:Diameter:0.00
    19:12:01.655 : Config:Extr.1:MaxTemp:285
    19:12:01.655 : ok 14
    19:12:01.655 : ok 15
    19:12:01.657 : T:19.47 /0 B:21.10 /0 B@:0 @:0
    19:12:01.657 : ok 16
    19:12:01.657 : ok 17
    19:12:01.657 : RESCUE_STATE: OFF
    19:12:01.657 : ok 18
    19:12:01.657 : ok 19
    19:12:02.655 : wait
    19:12:02.657 : T:19.47 /0 B:20.85 /0 B@:0 @:0
    19:12:03.634 : wait
    19:12:03.745 : T:19.12 /0 B:21.10 /0 B@:0 @:0
    19:12:04.623 : wait
    19:12:04.848 : T:19.30 /0 B:21.10 /0 B@:0 @:0
    19:12:05.614 : wait
    19:12:06.045 : T:19.47 /0 B:20.98 /0 B@:0 @:0
    19:12:06.593 : wait
    19:12:07.028 : T:19.47 /0 B:21.10 /0 B@:0 @:0
    19:12:07.574 : wait
    19:12:08.126 : T:19.47 /0 B:20.98 /0 B@:0 @:0
    19:12:08.563 : wait
    19:12:09.218 : T:19.47 /0 B:20.98 /0 B@:0 @:0
    19:12:09.655 : wait
    19:12:10.307 : T:19.30 /0 B:21.10 /0 B@:0 @:0
    19:12:10.634 : wait
    19:12:11.408 : T:19.12 /0 B:21.10 /0 B@:0 @:0
    19:12:11.623 : wait
    19:12:12.507 : T:19.47 /0 B:21.10 /0 B@:0 @:0
    19:12:12.615 : wait
    19:12:13.596 : T:19.47 /0 B:20.98 /0 B@:0 @:0
    19:12:13.596 : wait
    19:12:14.144 : ok 20
    19:12:14.698 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    19:12:15.134 : wait
    19:12:15.785 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    19:12:16.127 : wait
    19:12:16.877 : T:19.82 /0 B:21.34 /0 B@:0 @:0
    19:12:17.094 : wait
    19:12:17.969 : T:20.12 /0 B:21.22 /0 B@:0 @:0
    19:12:18.074 : wait
    19:12:19.065 : wait
    19:12:19.067 : T:20.12 /0 B:21.34 /0 B@:0 @:0
    19:12:19.496 : G28
    19:12:19.614 : Slow command added:G28
    19:12:19.614 : ok 21
    19:12:20.279 : T:19.82 /0 B:21.34 /0 B@:0 @:0
    19:12:21.355 : T:20.00 /0 B:21.34 /0 B@:0 @:0
    19:12:21.684 : busy:processing
    19:12:22.457 : T:20.12 /0 B:21.34 /0 B@:0 @:0
    19:12:23.545 : T:19.65 /0 B:21.22 /0 B@:0 @:0
    19:12:23.654 : busy:processing
    19:12:24.313 : SelectExtruder:0
    19:12:24.313 : FlowMultiply:100
    19:12:24.313 : X:0.00 Y:0.00 Z:510.700 E:0.0000
    19:12:24.313 : wait
    19:12:24.647 : T:20.00 /0 B:21.34 /0 B@:0 @:0
    19:12:25.304 : wait
    19:12:25.733 : T:20.00 /0 B:21.22 /0 B@:0 @:0
    19:12:26.285 : wait
    19:12:26.825 : T:19.82 /0 B:21.34 /0 B@:0 @:0
    19:12:27.373 : wait
    19:12:27.925 : T:19.82 /0 B:21.46 /0 B@:0 @:0
    19:12:28.363 : wait
    19:12:29.015 : T:20.12 /0 B:21.22 /0 B@:0 @:0
    19:12:29.344 : wait
    19:12:29.404 : g30
    19:12:29.523 : ok 22
    19:12:30.106 : T:19.82 /0 B:21.46 /0 B@:0 @:0
    19:12:31.206 : T:20.00 /0 B:21.22 /0 B@:0 @:0
    19:12:31.534 : busy:processing
    19:12:32.401 : T:20.12 /0 B:21.34 /0 B@:0 @:0
    19:12:33.396 : T:19.82 /0 B:21.34 /0 B@:0 @:0
    19:12:33.503 : busy:processing
    19:12:34.490 : T:20.00 /0 B:21.22 /0 B@:0 @:0
    19:12:35.575 : busy:processing
    19:12:35.577 : T:19.82 /0 B:21.10 /0 B@:0 @:0
    19:12:36.676 : T:20.12 /0 B:21.34 /0 B@:0 @:0
    19:12:37.544 : busy:processing
    19:12:37.763 : T:19.82 /0 B:21.46 /0 B@:0 @:0
    19:12:38.861 : T:19.65 /0 B:21.34 /0 B@:0 @:0
    19:12:39.513 : busy:processing
    19:12:39.946 : T:20.00 /0 B:21.22 /0 B@:0 @:0
    19:12:40.414 : Dtr: false Rts: false
    19:12:41.046 : T:20.00 /0 B:21.34 /0 B@:0 @:0
    19:12:41.594 : Response while unconnected:busy:processing
    19:12:41.594 : busy:processing
    19:12:42.147 : T:20.00 /0 B:21.22 /0 B@:0 @:0
    19:12:43.239 : T:20.00 /0 B:21.34 /0 B@:0 @:0
    19:12:43.564 : Response while unconnected:busy:processing
    19:12:43.564 : busy:processing
    19:12:44.332 : T:19.82 /0 B:21.34 /0 B@:0 @:0
    19:12:45.525 : T:19.82 /0 B:21.22 /0 B@:0 @:0
    19:12:45.525 : Response while unconnected:busy:processing
    19:12:45.525 : busy:processing
    19:12:46.625 : T:20.12 /0 B:21.46 /0 B@:0 @:0
    19:12:47.494 : Response while unconnected:busy:processing
    19:12:47.494 : busy:processing
    19:12:47.715 : T:20.12 /0 B:21.22 /0 B@:0 @:0
    19:12:48.817 : T:20.12 /0 B:21.34 /0 B@:0 @:0
    19:12:49.466 : Response while unconnected:busy:processing
    19:12:49.466 : busy:processing
    19:12:49.905 : T:20.24 /0 B:21.59 /0 B@:0 @:0
    19:12:51.417 : Dtr: false Rts: false
    19:12:51.417 : Connection started
    19:12:51.467 : T:19.82 /0 B:21 /0 B@:0 @:0
    19:12:52.329 : start
    19:12:52.329 : Info:External Reset
    19:12:52.329 : Detected EEPROM version:20
    19:12:52.436 : Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
    19:12:53.564 : zDistortionCorrection:0
    19:12:53.564 : Free RAM:971
    19:12:53.681 : Card successfully initialized.
    19:12:53.681 : Autoretract:0
    19:12:53.681 : X:0.00 Y:0.00 Z:0.000 E:0.0000
    19:12:53.681 : SelectExtruder:0
    19:12:53.681 : FlowMultiply:100
    19:12:53.681 : ok
    19:12:53.828 : ok 1
    19:12:53.828 : DebugLevel:6
    19:12:53.829 : info:Continue from fatal state
    19:12:53.829 : ok
    19:12:53.829 : ok 2
    19:12:53.831 : T:19.65 /0 B:21.22 /0 B@:0 @:0
    19:12:53.831 : ok 3
    19:12:53.831 : FIRMWARE_NAME:Repetier_1.0.4 COMPILED:Aug 22 2020 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
    19:12:53.831 : Cap:PROGRESS:1
    19:12:53.831 : M155 S1
    19:12:53.831 : Cap:AUTOREPORT_TEMP:1
    19:12:53.831 : Cap:HOST_RESCUE:1
    19:12:53.831 : Cap:EEPROM:1
    19:12:53.831 : Cap:AUTOLEVEL:1
    19:12:53.832 : Cap:Z_PROBE:1
    19:12:53.832 : Cap:SOFTWARE_POWER:1
    19:12:53.832 : Cap:TOGGLE_LIGHTS:0
    19:12:53.832 : Cap:PAUSESTOP:1
    19:12:53.832 : Cap:PREHEAT:1
    19:12:53.832 : Cap:EMERGENCY_PARSER:0
    19:12:53.832 : Printed filament:8306.03m Printing time:55 days 10 hours 26 min
    19:12:53.832 : PrinterMode:FFF
    19:12:53.832 : ok 4
    19:12:53.832 : SpeedMultiply:100
    19:12:53.832 : ok 5
    19:12:53.832 : FlowMultiply:100
    19:12:53.833 : ok 6
    19:12:53.833 : Info:No case lights
    19:12:53.833 : ok 7
    19:12:53.833 : ok 8
    19:12:53.833 : ok 9
    19:12:53.833 : ok 10
    19:12:53.833 : ok 11
    19:12:53.833 : X:0.00 Y:0.00 Z:0.000 E:0.0000
    19:12:53.833 : ok 12
    19:12:53.833 : DebugLevel:6
    19:12:53.833 : ok 13
    19:12:53.833 : Config:Baudrate:115200
    19:12:53.833 : Config:InputBuffer:127
    19:12:53.833 : Config:NumExtruder:1
    19:12:53.833 : Config:MixingExtruder:0
    19:12:53.833 : Config:HeatedBed:1
    19:12:53.833 : Config:SDCard:1
    19:12:53.833 : Config:Fan:1
    19:12:53.833 : Config:Fan2:0
    19:12:53.833 : Config:LCD:1
    19:12:53.834 : Config:SoftwarePowerSwitch:1
    19:12:53.834 : Config:XHomeDir:1
    19:12:53.834 : Config:YHomeDir:1
    19:12:53.834 : Config:ZHomeDir:1
    19:12:53.834 : Config:XHomePos:0.00
    19:12:53.834 : Config:YHomePos:0.00
    19:12:53.834 : Config:ZHomePos:510.700
    19:12:53.834 : Config:SupportG10G11:1
    19:12:53.834 : Config:SupportLocalFilamentchange:1
    19:12:53.834 : Config:CaseLights:0
    19:12:53.834 : Config:ZProbe:1
    19:12:53.834 : Config:Autolevel:1
    19:12:53.958 : Config:EEPROM:1
    19:12:53.958 : Config:PrintlineCache:16
    19:12:53.958 : Config:JerkXY:20.00
    19:12:53.958 : Config:KeepAliveInterval:2000
    19:12:53.958 : Config:RetractionLength:3.00
    19:12:53.958 : Config:RetractionLongLength:13.00
    19:12:53.958 : Config:RetractionSpeed:40.00
    19:12:53.958 : Config:RetractionZLift:0.00
    19:12:53.958 : Config:RetractionUndoExtraLength:0.00
    19:12:53.958 : Config:RetractionUndoExtraLongLength:0.00
    19:12:53.958 : Config:RetractionUndoSpeed:20.00
    19:12:53.958 : Config:XMin:0.00
    19:12:53.959 : Config:YMin:0.00
    19:12:53.959 : Config:ZMin:0.00
    19:12:53.959 : Config:XMax:588.40
    19:12:53.959 : Config:YMax:588.40
    19:12:53.959 : Config:ZMax:510.70
    19:12:53.959 : Config:XSize:588.40
    19:12:53.959 : Config:YSize:588.40
    19:12:53.959 : Config:ZSize:510.70
    19:12:53.959 : Config:XPrintAccel:1000.00
    19:12:53.959 : Config:YPrintAccel:1000.00
    19:12:53.959 : Config:ZPrintAccel:1000.00
    19:12:53.959 : Config:XTravelAccel:1000.00
    19:12:53.959 : Config:YTravelAccel:1000.00
    19:12:53.959 : Config:ZTravelAccel:1000.00
    19:12:53.959 : Config:PrinterType:Delta
    19:12:53.959 : Config:MaxBedTemp:120
    19:12:53.959 : Config:Extr.1:Jerk:20.00
    19:12:53.959 : Config:Extr.1:MaxSpeed:50.00
    19:12:53.959 : Config:Extr.1:Acceleration:5000.00
    19:12:53.959 : Config:Extr.1:Diameter:0.00
    19:12:53.959 : Config:Extr.1:MaxTemp:285
    19:12:53.959 : ok 14
    19:12:53.959 : ok 15
    19:12:53.961 : T:19.47 /0 B:20.85 /0 B@:0 @:0
    19:12:53.961 : ok 16
    19:12:53.961 : ok 17
    19:12:53.961 : RESCUE_STATE: OFF
    19:12:53.961 : ok 18
    19:12:54.063 : ok 19
    19:12:55.054 : wait
    19:12:55.056 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    19:12:55.984 : wait
    19:12:56.079 : T:19.47 /0 B:20.98 /0 B@:0 @:0
    19:12:57.045 : wait
    19:12:57.263 : T:19.47 /0 B:20.98 /0 B@:0 @:0
    19:12:58.043 : wait
    19:12:58.381 : T:19.47 /0 B:21.10 /0 B@:0 @:0
    19:12:59.054 : wait
    19:12:59.386 : T:19.47 /0 B:21.10 /0 B@:0 @:0
    19:13:00.023 : wait
    19:13:00.576 : T:19.30 /0 B:20.98 /0 B@:0 @:0
    19:13:00.904 : wait
    19:13:01.664 : T:19.47 /0 B:21.10 /0 B@:0 @:0
    19:13:01.880 : wait
    19:13:02.764 : T:19.47 /0 B:21.10 /0 B@:0 @:0
    19:13:02.873 : wait
    19:13:03.864 : T:19.30 /0 B:21.10 /0 B@:0 @:0
    19:13:03.978 : wait
    19:13:04.956 : T:19.47 /0 B:20.98 /0 B@:0 @:0
    19:13:04.956 : wait
    19:13:05.934 : wait
    19:13:06.051 : T:18.60 /0 B:20.98 /0 B@:0 @:0
    19:13:06.486 : ok 20
    19:13:07.145 : T:19.65 /0 B:20.98 /0 B@:0 @:0
    19:13:07.465 : wait
    19:13:08.234 : T:19.47 /0 B:20.98 /0 B@:0 @:0
    19:13:08.452 : wait
    19:13:09.325 : T:19.47 /0 B:21.10 /0 B@:0 @:0
    19:13:09.432 : wait
    19:13:10.316 : T:19.47 /0 B:20.98 /0 B@:0 @:0
    19:13:10.422 : wait
    19:13:11.415 : wait
    19:13:11.417 : T:19.30 /0 B:20.85 /0 B@:0 @:0
    19:13:12.388 : wait
    19:13:12.587 : T:19.47 /0 B:20.98 /0 B@:0 @:0
    19:13:13.493 : wait
    19:13:13.604 : T:19.47 /0 B:20.98 /0 B@:0 @:0
    19:13:14.472 : wait
    19:13:14.695 : T:19.47 /0 B:20.98 /0 B@:0 @:0
    19:13:15.453 : wait
    19:13:15.896 : T:20.00 /0 B:21.34 /0 B@:0 @:0
    19:13:16.432 : wait
    19:13:16.984 : T:19.47 /0 B:20.98 /0 B@:0 @:0
    19:13:17.423 : wait
    19:13:18.076 : T:19.47 /0 B:21.10 /0 B@:0 @:0
    19:13:18.402 : wait
    19:13:19.175 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    19:13:19.493 : wait
    19:13:20.265 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    19:13:20.483 : wait
    19:13:21.366 : T:19.47 /0 B:20.98 /0 B@:0 @:0
    19:13:21.473 : wait
    Please let me know if you need anything else.
    Thank you!
  • I only saw this
    19:11:51.455 : g32
    7 seconds is not even enough to do the first homing for G32 or am I wrong here?
    I expect to see homing then z probe results from 2 points and hopyfully the positions tried by third point that is way off as you say.
    Please also check if eeprom has stored same positions as your configuration file. If not that also explains the problem.
  • edited August 2020
    Right now the eeprom and the fimware have the same have the same positions for the probe points.  I thought maybe some videos might help.  I made a video repeating the g32 and g30 tests above  with Z_PROBE_REPETITIONS set to 3 as before.
    https://drive.google.com/file/d/1du95y3XKktyZkjn15kOKR0EmiCtVNSb-/view?usp=sharing
    I then set Z_PROBE_REPETITIONS to 1 and made another video.  You can see it does not crash the nozzle to the bed till the 3rd point.
    https://drive.google.com/file/d/1HOb1OkNIJC6LaZlEY7LiK2VlYMFnCEBc/view?usp=sharing
    Here are the logs from the second video.  Please let me know if this helps or if you have some other questions that would help.
    17:55:08.418 : Repetier-Server successfully connected.
    17:55:08.585 : wait
    17:55:08.746 : M115
    17:55:08.905 : ok 21
    17:55:08.905 : FIRMWARE_NAME:Repetier_1.0.4 COMPILED:Aug 25 2020 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
    17:55:08.905 : Cap:PROGRESS:1
    17:55:08.906 : M155 S1
    17:55:08.906 : Cap:AUTOREPORT_TEMP:1
    17:55:08.906 : Cap:HOST_RESCUE:1
    17:55:08.906 : Cap:EEPROM:1
    17:55:08.906 : Cap:AUTOLEVEL:1
    17:55:08.906 : Cap:Z_PROBE:1
    17:55:08.906 : Cap:SOFTWARE_POWER:1
    17:55:08.906 : Cap:TOGGLE_LIGHTS:0
    17:55:08.906 : Cap:PAUSESTOP:1
    17:55:08.906 : Cap:PREHEAT:1
    17:55:08.906 : Cap:EMERGENCY_PARSER:0
    17:55:08.906 : Printed filament:8306.03m Printing time:55 days 10 hours 26 min
    17:55:08.906 : PrinterMode:FFF
    17:55:08.906 : ok 22
    17:55:08.906 : ok 23
    17:55:08.906 : RESCUE_STATE: OFF
    17:55:09.021 : ok 24
    17:55:10.019 : wait
    17:55:10.131 : T:19.47 /0 B:21.22 /0 B@:0 @:0
    17:55:11.005 : wait
    17:55:11.238 : T:19.82 /0 B:21.22 /0 B@:0 @:0
    17:55:11.994 : wait
    17:55:12.331 : T:19.82 /0 B:21.22 /0 B@:0 @:0
    17:55:12.963 : wait
    17:55:13.409 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    17:55:13.552 : G28
    17:55:13.672 : ok 25
    17:55:14.178 : SelectExtruder:0
    17:55:14.178 : FlowMultiply:100
    17:55:14.178 : X:0.00 Y:0.00 Z:510.700 E:0.0000
    17:55:14.506 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    17:55:14.741 : wait
    17:55:15.621 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    17:55:15.733 : wait
    17:55:16.718 : wait
    17:55:16.720 : T:19.30 /0 B:21.10 /0 B@:0 @:0
    17:55:17.712 : wait
    17:55:17.830 : T:19.47 /0 B:21.10 /0 B@:0 @:0
    17:55:18.692 : wait
    17:55:18.913 : T:19.82 /0 B:21.22 /0 B@:0 @:0
    17:55:19.670 : wait
    17:55:20.004 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    17:55:20.772 : wait
    17:55:21.102 : T:19.82 /0 B:21.10 /0 B@:0 @:0
    17:55:21.752 : wait
    17:55:22.198 : T:20.00 /0 B:21.22 /0 B@:0 @:0
    17:55:22.624 : g32
    17:55:22.742 : wait
    17:55:22.742 : ok 26
    17:55:22.742 : Z correction disabled
    17:55:23.294 : T:19.65 /0 B:21.22 /0 B@:0 @:0
    17:55:24.384 : T:19.65 /0 B:20.85 /0 B@:0 @:0
    17:55:24.701 : busy:processing
    17:55:25.578 : T:19.47 /0 B:21.10 /0 B@:0 @:0
    17:55:26.564 : T:20.00 /0 B:21.10 /0 B@:0 @:0
    17:55:26.781 : busy:processing
    17:55:27.764 : Z-probe:21.062 X:-60.00 Y:-60.00
    17:55:27.983 : T:19.47 /0 B:21.10 /0 B@:0 @:0
    17:55:28.755 : busy:processing
    17:55:28.981 : T:19.82 /0 B:21.10 /0 B@:0 @:0
    17:55:30.063 : T:19.82 /0 B:21.10 /0 B@:0 @:0
    17:55:30.735 : busy:processing
    17:55:31.170 : T:19.65 /0 B:20.98 /0 B@:0 @:0
    17:55:32.261 : T:18.42 /0 B:20.98 /0 B@:0 @:0
    17:55:32.694 : busy:processing
    17:55:33.359 : T:19.30 /0 B:20.98 /0 B@:0 @:0
    17:55:34.445 : T:19.82 /0 B:21.22 /0 B@:0 @:0
    17:55:34.784 : busy:processing
    17:55:35.533 : T:19.30 /0 B:21.10 /0 B@:0 @:0
    17:55:36.656 : T:19.82 /0 B:21.10 /0 B@:0 @:0
    17:55:36.762 : busy:processing
    17:55:37.733 : T:19.82 /0 B:21.22 /0 B@:0 @:0
    17:55:38.706 : busy:processing
    17:55:38.832 : T:20.00 /0 B:21.22 /0 B@:0 @:0
    17:55:40.030 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    17:55:40.788 : busy:processing
    17:55:41.118 : T:19.82 /0 B:21.10 /0 B@:0 @:0
    17:55:41.380 : Dtr: false Rts: false
    17:55:42.205 : T:19.82 /0 B:21.10 /0 B@:0 @:0
    17:55:42.754 : Response while unconnected:busy:processing
    17:55:42.754 : busy:processing
    17:55:43.298 : T:19.82 /0 B:21.10 /0 B@:0 @:0
    17:55:44.430 : T:20.00 /0 B:21.10 /0 B@:0 @:0
    17:55:44.769 : Response while unconnected:busy:processing
    17:55:44.770 : busy:processing
    17:55:45.516 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    17:55:46.405 : Error:Z-probe failed
    17:55:46.405 : Error:Probing had returned errors - autoleveling canceled.
    17:55:46.405 : ;@stop
    17:55:46.405 : Response while unconnected:RequestStop:
    17:55:46.406 : ;@stop
    17:55:46.406 : RequestStop:
    17:55:46.406 : Error:A hit floor
    17:55:46.406 : Warning:Invalid delta coordinate - move ignored x:4800 y:-4800 z:-79792
    17:55:46.406 : Warning:in queueDeltaMove to calculateDeltaSubSegments returns error.
    17:55:46.406 : Warning:moveRelativeDistanceInSteps / queueDeltaMove returns error
    17:55:46.407 : TargetExtr0:0
    17:55:46.408 : T:20.12 /0 B:21.22 /0 B@:0 @:0
    17:55:46.530 : Response while unconnected:fatal:G32 leveling failed! - Printer stopped and heaters dstart
    17:55:46.530 : fatal:G32 leveling failed! - Printer stopped and heaters dstart
    17:55:46.530 : Detected EEPROM version:20
    17:55:46.531 : Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
    17:55:48.066 : zDistortionCorrection:0
    17:55:48.066 : Free RAM:971
    17:55:48.067 : Card successfully initialized.
    17:55:48.067 : Autoretract:0
    17:55:48.068 : X:0.00 Y:0.00 Z:0.000 E:0.0000
    17:55:48.068 : SelectExtruder:0
    17:55:48.068 : FlowMultiply:100
    17:55:48.068 : ok 1
    17:55:48.068 : ok 2
    17:55:48.068 : ok 3
    17:55:48.068 : DebugLevel:6
    17:55:48.068 : ok 4
    17:55:48.068 : Config:Baudrate:115200
    17:55:48.068 : Config:InputBuffer:127
    17:55:48.069 : Config:NumExtruder:1
    17:55:48.069 : Config:MixingExtruder:0
    17:55:48.069 : Config:HeatedBed:1
    17:55:48.069 : Config:SDCard:1
    17:55:48.069 : Config:Fan:1
    17:55:48.069 : Config:Fan2:0
    17:55:48.069 : Config:LCD:1
    17:55:48.069 : Config:SoftwarePowerSwitch:1
    17:55:48.069 : Config:XHomeDir:1
    17:55:48.069 : Config:YHomeDir:1
    17:55:48.069 : Config:ZHomeDir:1
    17:55:48.069 : Config:XHomePos:0.00
    17:55:48.069 : Config:YHomePos:0.00
    17:55:48.069 : Config:ZHomePos:510.700
    17:55:48.069 : Config:SupportG10G11:1
    17:55:48.069 : Config:SupportLocalFilamentchange:1
    17:55:48.069 : Config:CaseLights:0
    17:55:48.070 : Config:ZProbe:1
    17:55:48.070 : Config:Autolevel:1
    17:55:48.070 : Config:EEPROM:1
    17:55:48.070 : Config:PrintlineCache:16
    17:55:48.070 : Config:JerkXY:20.00
    17:55:48.070 : Config:KeepAliveInterval:2000
    17:55:48.070 : Config:RetractionLength:3.00
    17:55:48.070 : Config:RetractionLongLength:13.00
    17:55:48.070 : Config:RetractionSpeed:40.00
    17:55:48.070 : Config:RetractionZLift:0.00
    17:55:48.070 : Config:RetractionUndoExtraLength:0.00
    17:55:48.070 : Config:RetractionUndoExtraLongLength:0.00
    17:55:48.070 : Config:RetractionUndoSpeed:20.00
    17:55:48.070 : Config:XMin:0.00
    17:55:48.070 : Config:YMin:0.00
    17:55:48.070 : Config:ZMin:0.00
    17:55:48.070 : Config:XMax:588.40
    17:55:48.071 : Config:YMax:588.40
    17:55:48.071 : Config:ZMax:510.70
    17:55:48.071 : Config:XSize:588.40
    17:55:48.071 : Config:YSize:588.40
    17:55:48.071 : Config:ZSize:510.70
    17:55:48.074 : Config:XPrintAccel:1000.00
    17:55:48.074 : Config:YPrintAccel:1000.00
    17:55:48.074 : Config:ZPrintAccel:1000.00
    17:55:48.074 : Config:XTravelAccel:1000.00
    17:55:48.075 : Config:YTravelAccel:1000.00
    17:55:48.075 : Config:ZTravelAccel:1000.00
    17:55:48.075 : Config:PrinterType:Delta
    17:55:48.075 : Config:MaxBedTemp:120
    17:55:48.075 : Config:Extr.1:Jerk:20.00
    17:55:48.075 : Config:Extr.1:MaxSpeed:50.00
    17:55:48.075 : Config:Extr.1:Acceleration:5000.00
    17:55:48.075 : Config:Extr.1:Diameter:0.00
    17:55:48.075 : Config:Extr.1:MaxTemp:285
    17:55:48.075 : ok 5
    17:55:48.075 : ok
    17:55:48.075 : ok 1
    17:55:48.075 : DebugLevel:6
    17:55:48.075 : info:Continue from fatal state
    17:55:48.075 : ok
    17:55:48.075 : ok 2
    17:55:48.085 : T:19.82 /0 B:20.98 /0 B@:0 @:0
    17:55:48.085 : ok 3
    17:55:48.086 : FIRMWARE_NAME:Repetier_1.0.4 COMPILED:Aug 25 2020 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
    17:55:48.086 : Cap:PROGRESS:1
    17:55:48.087 : M155 S1
    17:55:48.087 : Cap:AUTOREPORT_TEMP:1
    17:55:48.087 : Cap:HOST_RESCUE:1
    17:55:48.087 : Cap:EEPROM:1
    17:55:48.087 : Cap:AUTOLEVEL:1
    17:55:48.087 : Cap:Z_PROBE:1
    17:55:48.087 : Cap:SOFTWARE_POWER:1
    17:55:48.087 : Cap:TOGGLE_LIGHTS:0
    17:55:48.087 : Cap:PAUSESTOP:1
    17:55:48.088 : Cap:PREHEAT:1
    17:55:48.088 : Cap:EMERGENCY_PARSER:0
    17:55:48.088 : Printed filament:8306.03m Printing time:55 days 10 hours 26 min
    17:55:48.088 : PrinterMode:FFF
    17:55:48.088 : ok 4
    17:55:48.089 : SpeedMultiply:100
    17:55:48.089 : ok 5
    17:55:48.089 : FlowMultiply:100
    17:55:48.089 : ok 6
    17:55:48.090 : Info:No case lights
    17:55:48.090 : ok 7
    17:55:48.090 : ok 8
    17:55:48.090 : ok 9
    17:55:48.090 : ok 10
    17:55:48.090 : ok 11
    17:55:48.132 : X:0.00 Y:0.00 Z:0.000 E:0.0000
    17:55:48.132 : ok 12
    17:55:48.132 : DebugLevel:6
    17:55:48.132 : ok 13
    17:55:48.133 : Config:Baudrate:115200
    17:55:48.133 : Config:InputBuffer:127
    17:55:48.133 : Config:NumExtruder:1
    17:55:48.133 : Config:MixingExtruder:0
    17:55:48.133 : Config:HeatedBed:1
    17:55:48.133 : Config:SDCard:1
    17:55:48.133 : Config:Fan:1
    17:55:48.133 : Config:Fan2:0
    17:55:48.133 : Config:LCD:1
    17:55:48.133 : Config:SoftwarePowerSwitch:1
    17:55:48.133 : Config:XHomeDir:1
    17:55:48.133 : Config:YHomeDir:1
    17:55:48.133 : Config:ZHomeDir:1
    17:55:48.133 : Config:XHomePos:0.00
    17:55:48.133 : Config:YHomePos:0.00
    17:55:48.134 : Config:ZHomePos:510.700
    17:55:48.134 : Config:SupportG10G11:1
    17:55:48.134 : Config:SupportLocalFilamentchange:1
    17:55:48.134 : Config:CaseLights:0
    17:55:48.134 : Config:ZProbe:1
    17:55:48.134 : Config:Autolevel:1
    17:55:48.134 : Config:EEPROM:1
    17:55:48.134 : Config:PrintlineCache:16
    17:55:48.134 : Config:JerkXY:20.00
    17:55:48.134 : Config:KeepAliveInterval:2000
    17:55:48.134 : Config:RetractionLength:3.00
    17:55:48.134 : Config:RetractionLongLength:13.00
    17:55:48.134 : Config:RetractionSpeed:40.00
    17:55:48.134 : Config:RetractionZLift:0.00
    17:55:48.134 : Config:RetractionUndoExtraLength:0.00
    17:55:48.134 : Config:RetractionUndoExtraLongLength:0.00
    17:55:48.135 : Config:RetractionUndoSpeed:20.00
    17:55:48.135 : Config:XMin:0.00
    17:55:48.135 : Config:YMin:0.00
    17:55:48.135 : Config:ZMin:0.00
    17:55:48.135 : Config:XMax:588.40
    17:55:48.135 : Config:YMax:588.40
    17:55:48.135 : Config:ZMax:510.70
    17:55:48.135 : Config:XSize:588.40
    17:55:48.135 : Config:YSize:588.40
    17:55:48.135 : Config:ZSize:510.70
    17:55:48.135 : Config:XPrintAccel:1000.00
    17:55:48.135 : Config:YPrintAccel:1000.00
    17:55:48.135 : Config:ZPrintAccel:1000.00
    17:55:48.135 : Config:XTravelAccel:1000.00
    17:55:48.135 : Config:YTravelAccel:1000.00
    17:55:48.135 : Config:ZTravelAccel:1000.00
    17:55:48.135 : Config:PrinterType:Delta
    17:55:48.135 : Config:MaxBedTemp:120
    17:55:48.136 : Config:Extr.1:Jerk:20.00
    17:55:48.136 : Config:Extr.1:MaxSpeed:50.00
    17:55:48.136 : Config:Extr.1:Acceleration:5000.00
    17:55:48.136 : Config:Extr.1:Diameter:0.00
    17:55:48.136 : Config:Extr.1:MaxTemp:285
    17:55:48.136 : ok 14
    17:55:48.136 : ok 15
    17:55:48.232 : ok 16
    17:55:48.232 : ok 17
    17:55:48.232 : RESCUE_STATE: OFF
    17:55:48.232 : ok 18
    17:55:48.232 : ok 19
    17:55:49.233 : wait
    17:55:49.355 : T:19.12 /0 B:20.85 /0 B@:0 @:0
    17:55:50.363 : wait
    17:55:50.439 : T:19.12 /0 B:20.73 /0 B@:0 @:0
    17:55:51.225 : wait
    17:55:51.560 : T:19.12 /0 B:20.73 /0 B@:0 @:0
    17:55:52.192 : wait
    17:55:52.642 : T:19.82 /0 B:21.22 /0 B@:0 @:0
    17:55:53.182 : wait
    17:55:53.745 : T:19.65 /0 B:20.98 /0 B@:0 @:0
    17:55:54.228 : wait
    17:55:54.828 : T:19.82 /0 B:21.22 /0 B@:0 @:0
    17:55:55.254 : wait
    17:55:55.925 : T:19.82 /0 B:20.85 /0 B@:0 @:0
    17:55:56.233 : wait
    17:55:56.943 : G28
    17:55:57.067 : T:19.82 /0 B:21.10 /0 B@:0 @:0
    17:55:57.067 : ok 20
    17:55:57.988 : T:19.82 /0 B:21.10 /0 B@:0 @:0
    17:55:58.974 : busy:processing
    17:55:59.093 : T:19.65 /0 B:20.98 /0 B@:0 @:0
    17:56:00.195 : T:20.00 /0 B:20.98 /0 B@:0 @:0
    17:56:01.058 : busy:processing
    17:56:01.396 : T:19.82 /0 B:21.10 /0 B@:0 @:0
    17:56:01.827 : SelectExtruder:0
    17:56:01.827 : FlowMultiply:100
    17:56:01.828 : X:0.00 Y:0.00 Z:510.700 E:0.0000
    17:56:01.828 : wait
    17:56:02.475 : T:19.30 /0 B:21.34 /0 B@:0 @:0
    17:56:02.802 : wait
    17:56:03.563 : T:19.82 /0 B:21.34 /0 B@:0 @:0
    17:56:03.784 : wait
    17:56:04.663 : T:19.65 /0 B:21.22 /0 B@:0 @:0
    17:56:04.873 : wait
    17:56:05.761 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    17:56:05.862 : wait
    17:56:06.861 : T:19.65 /0 B:20.98 /0 B@:0 @:0
    17:56:06.861 : wait
    17:56:07.826 : wait
    17:56:07.935 : T:19.65 /0 B:21.22 /0 B@:0 @:0
    17:56:08.815 : wait
    17:56:09.035 : T:19.82 /0 B:21.22 /0 B@:0 @:0
    17:56:09.801 : wait
    17:56:10.134 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    17:56:10.893 : wait
    17:56:11.231 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    17:56:11.882 : wait
    17:56:12.325 : T:19.47 /0 B:21.22 /0 B@:0 @:0
    17:56:12.865 : wait
    17:56:13.423 : T:19.30 /0 B:20.98 /0 B@:0 @:0
    17:56:13.855 : wait
    17:56:14.508 : T:20.12 /0 B:21.10 /0 B@:0 @:0
    17:56:14.843 : wait
    17:56:15.606 : T:19.47 /0 B:21.10 /0 B@:0 @:0
    17:56:15.826 : wait
    17:56:16.704 : T:19.82 /0 B:21.10 /0 B@:0 @:0
    17:56:16.826 : wait
    17:56:17.908 : T:20.00 /0 B:21.10 /0 B@:0 @:0
    17:56:17.908 : wait
    17:56:18.886 : wait
    17:56:18.997 : T:19.82 /0 B:21.22 /0 B@:0 @:0
    17:56:19.718 : g30
    17:56:19.879 : wait
    17:56:19.879 : ok 21
    17:56:20.101 : T:19.82 /0 B:21.22 /0 B@:0 @:0
    17:56:21.192 : T:20.00 /0 B:20.98 /0 B@:0 @:0
    17:56:21.831 : busy:processing
    17:56:22.270 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    17:56:23.361 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    17:56:23.900 : busy:processing
    17:56:24.457 : T:19.65 /0 B:20.85 /0 B@:0 @:0
    17:56:25.542 : T:19.47 /0 B:21.10 /0 B@:0 @:0
    17:56:25.868 : busy:processing
    17:56:26.534 : T:19.65 /0 B:20.98 /0 B@:0 @:0
    17:56:27.644 : T:19.65 /0 B:20.85 /0 B@:0 @:0
    17:56:27.862 : busy:processing
    17:56:28.734 : T:19.47 /0 B:21.10 /0 B@:0 @:0
    17:56:29.826 : busy:processing
    17:56:29.830 : T:19.82 /0 B:20.98 /0 B@:0 @:0
    17:56:31.033 : T:19.65 /0 B:21.22 /0 B@:0 @:0
    17:56:31.900 : busy:processing
    17:56:32.131 : T:20.00 /0 B:21.10 /0 B@:0 @:0
    17:56:32.332 : Z-probe:516.213 X:0.00 Y:0.00
    17:56:32.443 : wait
    17:56:33.219 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    17:56:33.527 : wait
    17:56:34.295 : T:19.65 /0 B:21.10 /0 B@:0 @:0
    17:56:34.515 : wait
    17:56:35.397 : T:19.47 /0 B:21.22 /0 B@:0 @:0
    17:56:35.502 : wait
    17:56:36.538 : wait
    17:56:36.539 : T:20.00 /0 B:21.22 /0 B@:0 @:0
    17:56:37.478 : wait
    17:56:37.600 : T:19.47 /0 B:20.98 /0 B@:0 @:0
    17:56:38.519 : wait
  • I think you are moving too fast for the sensor. It looks like the z probe does not trigger and what you see is the large negative move that continues. BLtouch is critical on timings. So I think you should add a delay after each probe.
    #define Z_PROBE_DELAY 200
    Also you should reduce z probe speed to increase precision.
    I hope that the probe then correctly triggeres on touch.
  • I set the  Z_PROBE_DELAY to 200 and lowered my speed.  Unfortunately, it did not make the nozzle crash on the third touch go away.  Going slower did give me more time to unplug the printer to stop the nozzle crash on the third touch.
    My wife came up with a great Idea to get more information for troubleshooting this.  I tried a different Mega 2560 board.  I switched my fake Arduino Mega 2560 R3 for my son's Elegoo Mega 2560 R3 clone.  It made the issue worse by making the nozzle crash on the second touch dependably instead of the third touch.  This is the first time I have been able to make a change to the issue.  Now what we need to figure out is what is different in the two boards and then what we can change in the firmware settings to tolerate a complete G32 auto-level without crashing the nozzle into the bed on any of the touches.  What do you think I should try changing?  I really appreciate your help!
  • You should try ZPROBE_PULLUP 1 - that is how I did it on my delta with BLtouch. Since problem is getting a signal that might be the key as it has big influence on the signal. Would also be the only thing I can think of making a difference.
  • I tried the ZPROBE_PULLUP 1 on my fake Arduino Mega 2560 R3 and the nozzle still crashes into the bed on the third touch.
    The thing that troubles me about this issue is that the first two touches work and then it suddenly either it cannot see the signal or it ignores the signal from the BL Touch on the third touch.  In most cases I would think either none of the touches would work or all of the touches would fail.  My gut feeling is that this is some unexpected hardware limitation of my 2560 boards.  But, I cannot prove it nor can I figure out how to work around it.   ....yet.  What are your next ideas?  .... and again, thank you for your help!
  • Really wired. You could send
    M111 S71
    first. This enables endstop debugging so every time a end stop change is detected it writes a line. Might crash firmware if it changes too often. But with that you should see when a signal gets detected and that maybe shows that our current assumption that it does not trigger is correct or not. It might also be that the bltouch goes into error mode. It happens if after triggering you go not up fast enough. If you have multiple repetitions make sure it goes up high enough to untrigger the sensor - maybe 10mm. Low values only work with optical or magnetic switches.
  • @FlamingWidget : Have you set the BL-Touch to 5V manually, I had a similar issue, sometimes it worked sometimes not, but never could start a print job because somewhere the alarm get active. By checking the signals with oscilloscope it seems the "Logic voltage Free" mode is using ~3V but on the Ramps 5V is needed. After changing to 5V i could start the first print job an the probe didnt fail.
    I think it has to do with the voltage level which is not that exactly the same each time the probe hits ( tolerance) an this is why your printhead crashes when the level is too low ( on mine it was around 2,9V ) and is not recognized. With the oscilloscope this get visible. Also tried the delay etc.
    I checked you config too an I'm not sure if this command is necesssary or causes "something", because I do not use it and it works :
    Yours:
    Mine:
    #define Z_PROBE_RUN_AFTER_EVERY_PROBE ""
    My HW is also 2560 ( recently replaced by original ) with Ramps 1.6 and BL-Touch 3.1 Repetier FW and Server Pro.
  • Is seems this was only luck, on the second try probe alarm came up. Found out that the alarm comes when the probe is not rised in a certain amaount of time, it works when Z is rised within 240ms ( measured value ) and it do not work when it raises not for 1000ms ( dont know the real limits ) - print head crashes then, the question is here why it is not recognized properly and how can this be sporadically. The sensor itself is working fine. Lowering the speed to 0,5mm/s also didn't improved this.
  • Now I changed my wiring from Z min pin to Z max pin and it's working for several prints up to now. The high peak is actually about 180ms. Probe Speed is still 0,5mm/s but only one repetition. Don't know why but is seems like there is an issue with the Z min input on my ramps board ( i used the 2560 clone before and it was not workind an then i boutght the original arduino but had the same "problem" so I can exclude the 2560 board itself) . Regarding end switch capacitors on the ramps 1.6 I couldn't find something - so this can still be an issue maybe.
