Re-assigning auto levelling points..
Hello there, I recently increased my 3D printers size but when I hit "Auto level measurement" it still measures the bed as if it was untouched.(both EEPROM and Repetier knows the new size of the plate.) The bed originally was 300mm x 300mm and now 470mm x 400mm. Any idea how to get the firmware check the new surface..?
Thanks in advance..
  • What does this command execute?
    For G32 you need to change the z probe coordinates in eeprom.
    For G33 you have to change the size in configuration.h of firmware and recompile firmware.
