TH3D Lite board
I installed the TH3D Lite board in my CR-10s and now my repeiter server won’t connect. Is there an issue with this board that server doesn’t see it? I can connect to my Mac and see my board but I can’t with my raspberry pi repeiter server.
  • Don't have that board. So first question is do you see the serial belonging to the board? Next would be if you selected correct firmware and baud rate.
  • I can connect the board to s3d, and I can control the board through s3d, but when I connect it to repeater server, it doesn't see the board. Ids there a way to force look for the printer through the touchscreen of repeater server?
  • You need to add and configure it first using the regular web gui. Only after that it will be visible in the touch screen interface.
