Webcam Light Option (Not the status light)
Is there a way to enabled disable the light on a webcam via interface/setting? It's not great in the dark
  • Webcams normally have no lights. If you have a switchable light you can add a command to extcommands.xml as described in advanced configuration to execute a command that turns the light on or off. Or you printer might have a light that is switchable with M355 then you can switch it on/off with the light button if you said you have such a light.
