Windows web server for Repetier-Server
Hello,
I am going to be installing Repetier-Server on my Windows machine currently connected to my Sovol SV01 running Marlin 2.0. I  would like to access Repetier-Server via web gui from a different machine on my LAN. I see there are instruction on how to load nginx on linux / pi - is there a guide on how to install on Windows? Would I also use nginx or would I use IIS or some other web engine?
Best regards,
Mark
  • You don't need to install any webserver. All you need is to use the intranet ip:3344 instead of 127.0.0.1 or localhost. The server already has a webserver. The nginx webserver is just for convenience so you can omit the :3344.
