Re-scales drawing when going from inventor to Repetier
When I take a drawing that has been done on Inventor in mm to Repetier it is not the same size. Repetier is also set to mm.
How can I fix this?
  • Repetier-Host does assume 1 unit is 1mm be default or the conversion unit defined it host Config->Units of imported Objects. I don't know inventor so can not say if it really exports stl in mm or if it has a factor. Guess you know better what factor it is scaled wrong. If it is much too small you units are maybe meter not mm in inventor export.
