Firmware Update without configuration.h
Hi guys,
I bought a delta printer 2nd hand and its from a manufacturer that wend out of business a while ago.
The printer does not have any "mechanical" means to adjust the bed and I am planning to add a BL touch for bed leveling. For that I need to reflash Repetier. Unfortunately I have no configuration.h.
As the printer is a bit unique what would be the best strategy?
  • Make your own configuration and analyse which hardware is used. There is no way around this anyway if you have no old configuration file for the printer. Before you start extract everything you can e.g. from eeprom settings if it is repetier-firmware. Then you know already all dimensions you need to enter to get the old result.
  • Thank you! I extracted all settings I could. Checked EEPROM and Console and documented it all. Today I was brave enough to finally updated the firmware to 1.0.3 and enabled Autolevel and all corresponding options with BL Touch.
    After some minor back and forth I can see all 3 extruder temperatures as well as the bed. Step motors are moving and console output matches as well (e.g. Home Direction, Accelerations etc...). But all my movements are inverse. The printer homes to the top (position 0). Now when I hit home it goes straight into the bed. Also the X / Y / Z movements from the manual control are reversed. Tried to inverse the stepper movement in the configuration but then the motors lock up homing in top position.
    Not really sure what else to try. Help would be really appreciated. (Configuration.h will be in the next post).
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       This file is optimized for version 1.0.3
       as you expect.
    #define NUM_EXTRUDER 3
    #define MOTHERBOARD 402
    #define RFSERIAL Serial
    #include "pins.h"
    #undef FAN2_PIN
        #define FAN2_PIN -1
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 3
    #define XAXIS_STEPS_PER_MM 640
    #define YAXIS_STEPS_PER_MM 640
    #define ZAXIS_STEPS_PER_MM 640
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 370
    #define EXT0_STEP_PIN ORIG_E1_STEP_PIN
    #define EXT0_DIR_PIN ORIG_E1_DIR_PIN
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_PIN ORIG_E1_ENABLE_PIN
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define EXT1_X_OFFSET 0
    #define EXT1_Y_OFFSET 0
    #define EXT1_Z_OFFSET 0
    #define EXT1_STEPS_PER_MM 370
    #define EXT1_TEMPSENSOR_TYPE 1
    #define EXT1_STEP_PIN ORIG_E2_STEP_PIN
    #define EXT1_DIR_PIN ORIG_E2_DIR_PIN
    #define EXT1_INVERSE 0
    #define EXT1_ENABLE_PIN ORIG_E2_ENABLE_PIN
    #define EXT1_ENABLE_ON 0
    #define EXT1_MIRROR_STEPPER 0
    #define EXT1_INVERSE2 0
    #define EXT1_MAX_FEEDRATE 50
    #define EXT1_HEAT_MANAGER 3
    #define EXT1_PREHEAT_TEMP 190
    #define EXT1_WATCHPERIOD 1
    #define EXT1_PID_I 2
    #define EXT1_PID_D 40
    #define EXT1_PID_MAX 255
    #define EXT1_ADVANCE_K 0
    #define EXT1_ADVANCE_L 0
    #define EXT1_JAM_PIN -1
    #define EXT1_JAM_PULLUP 0
    #define EXT2_X_OFFSET 0
    #define EXT2_Y_OFFSET 0
    #define EXT2_Z_OFFSET 0
    #define EXT2_STEPS_PER_MM 370
    #define EXT2_TEMPSENSOR_TYPE 1
    #define EXT2_TEMPSENSOR_PIN TEMP_3_PIN
    #define EXT2_HEATER_PIN HEATER_3_PIN
    #define EXT2_STEP_PIN ORIG_E3_STEP_PIN
    #define EXT2_DIR_PIN ORIG_E3_DIR_PIN
    #define EXT2_INVERSE 0
    #define EXT2_ENABLE_PIN ORIG_E3_ENABLE_PIN
    #define EXT2_ENABLE_ON 0
    #define EXT2_MIRROR_STEPPER 0
    #define EXT2_STEP2_PIN ORIG_E2_STEP_PIN
    #define EXT2_DIR2_PIN ORIG_E2_DIR_PIN
    #define EXT2_INVERSE2 0
    #define EXT2_ENABLE2_PIN ORIG_E2_ENABLE_PIN
    #define EXT2_MAX_FEEDRATE 50
    #define EXT2_MAX_START_FEEDRATE 20
    #define EXT2_MAX_ACCELERATION 5000
    #define EXT2_HEAT_MANAGER 3
    #define EXT2_PREHEAT_TEMP 190
    #define EXT2_WATCHPERIOD 1
    #define EXT2_PID_INTEGRAL_DRIVE_MAX 230
    #define EXT2_PID_INTEGRAL_DRIVE_MIN 40
    #define EXT2_PID_PGAIN_OR_DEAD_TIME 7
    #define EXT2_PID_I 2
    #define EXT2_PID_D 40
    #define EXT2_PID_MAX 255
    #define EXT2_ADVANCE_K 0
    #define EXT2_ADVANCE_L 0
    #define EXT2_ADVANCE_BACKLASH_STEPS 0
    #define EXT2_WAIT_RETRACT_TEMP 150
    #define EXT2_WAIT_RETRACT_UNITS 0
    #define EXT2_SELECT_COMMANDS ""
    #define EXT2_DESELECT_COMMANDS ""
    #define EXT2_EXTRUDER_COOLER_PIN -1
    #define EXT2_EXTRUDER_COOLER_SPEED 255
    #define EXT2_DECOUPLE_TEST_PERIOD 12000
    #define EXT2_JAM_PIN -1
    #define EXT2_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define HEATED_BED_MAX_TEMP 95
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 280
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 1
    #define Y_ENABLE_ON 1
    #define Z_ENABLE_ON 1
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR 1
    #define Y_HOME_DIR 1
    #define Z_HOME_DIR 1
    #define X_MAX_LENGTH 220
    #define Y_MAX_LENGTH 220
    #define Z_MAX_LENGTH 391
    #define X_MIN_POS -110
    #define Y_MIN_POS -110
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 0
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_DIAGONAL_ROD 250 // mm
    #define DELTA_ALPHA_A 150
    #define DELTA_ALPHA_B 30
    #define DELTA_ALPHA_C 270
    #define DELTA_MAX_RADIUS 215
    #define ROD_RADIUS 126.3
    #define PRINTER_RADIUS 126.3
    #define DELTA_HOME_ON_POWER 0
    #define STEP_COUNTER
    //#define SOFTWARE_LEVELING
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 200
    #define HOMING_FEEDRATE_X 100
    #define HOMING_FEEDRATE_Y 100
    #define HOMING_FEEDRATE_Z 100
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define ENABLE_BACKLASH_COMPENSATION 1
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 2000
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 2000
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 2000
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 2000
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 2000
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 2000
    #define MAX_JERK 40
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 250000
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 2
    #undef PS_ON_PIN
    #define PS_ON_PIN -1
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    #define FEATURE_SERVO 1
    #define SERVO0_PIN 5
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 1
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 1
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_SWITCHING_DISTANCE 4
    #define Z_PROBE_REPETITIONS 2
    #define Z_PROBE_USE_MEDIAN 0
    #define Z_PROBE_HEIGHT 0
    #define Z_PROBE_DELAY 0
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 195
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 20
    #define Z_PROBE_Y3 195
    #define BED_LEVELING_METHOD 1
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #undef SDCARDDETECTINVERTED
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_FAN2_CONTROL 1
    #define FEATURE_CONTROLLER 0
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 1
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 1
    #define LANGUAGE_IT_ACTIVE 1
    #define LANGUAGE_ES_ACTIVE 1
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 1
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 1
    #define LANGUAGE_TR_ACTIVE 1
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN ORIG_FAN2_PIN
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define NUM_MOTOR_DRIVERS 0
        "editMode": 1,
        "processor": 1,
        "baudrate": 250000,
        "bluetoothSerial": -1,
        "bluetoothBaudrate": 115200,
        "xStepsPerMM": 640,
        "yStepsPerMM": 640,
        "zStepsPerMM": 640,
        "xInvert": 0,
        "x2Invert": 0,
        "xInvertEnable": "1",
        "eepromMode": 2,
        "yInvert": 0,
        "y2Invert": 0,
        "yInvertEnable": "1",
        "zInvert": 0,
        "z2Invert": 0,
        "z3Invert": 0,
        "z4Invert": 0,
        "zInvertEnable": "1",
        "extruder": [
                "id": 0,
                "heatManager": 3,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 1,
                "sensorPin": "TEMP_0_PIN",
                "heaterPin": "HEATER_0_PIN",
                "maxFeedrate": 50,
                "startFeedrate": 20,
                "invert": "0",
                "invertEnable": "0",
                "acceleration": 5000,
                "watchPeriod": 1,
                "pidP": 7,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetractTemp": 150,
                "waitRetractUnits": 0,
                "waitRetract": 0,
                "stepsPerMM": 370,
                "coolerPin": -1,
                "coolerSpeed": 255,
                "selectCommands": "",
                "deselectCommands": "",
                "xOffset": 0,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 1",
                    "step": "ORIG_E1_STEP_PIN",
                    "dir": "ORIG_E1_DIR_PIN",
                "advanceBacklashSteps": 0,
                "decoupleTestPeriod": 12,
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                    "name": "Extruder 0",
                    "step": "ORIG_E0_STEP_PIN",
                    "dir": "ORIG_E0_DIR_PIN",
                "preheat": 190
                "id": 1,
                "heatManager": 3,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 1,
                "sensorPin": "TEMP_2_PIN",
                "heaterPin": "HEATER_2_PIN",
                "maxFeedrate": 50,
                "invert": "0",
                "watchPeriod": 1,
                "pidP": 7,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetract": 0,
                "stepsPerMM": 370,
                "coolerPin": -1,
                "coolerSpeed": 255,
                "xOffset": 0,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 2",
                    "step": "ORIG_E2_STEP_PIN",
                    "dir": "ORIG_E2_DIR_PIN",
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "preheat": 190
                "id": 2,
                "heatManager": 3,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 1,
                "sensorPin": "TEMP_3_PIN",
                "heaterPin": "HEATER_3_PIN",
                "maxFeedrate": 50,
                "invert": "0",
                "watchPeriod": 1,
                "pidP": 7,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetract": 0,
                "stepsPerMM": 370,
                "coolerPin": -1,
                "coolerSpeed": 255,
                "xOffset": 0,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 3",
                    "step": "ORIG_E3_STEP_PIN",
                    "dir": "ORIG_E3_DIR_PIN",
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "preheat": 190
        "uiLanguage": 0,
        "uiController": 0,
        "xMinEndstop": 1,
        "yMinEndstop": 1,
        "zMinEndstop": 4,
        "xMaxEndstop": 0,
        "yMaxEndstop": 0,
        "zMaxEndstop": 0,
        "x2MinEndstop": 0,
        "y2MinEndstop": 0,
        "x2MaxEndstop": 0,
        "y2MaxEndstop": 0,
        "motherboard": 402,
        "driveSystem": 3,
        "xMaxSpeed": 200,
        "xHomingSpeed": 100,
        "xTravelAcceleration": 2000,
        "xPrintAcceleration": 2000,
        "yMaxSpeed": 200,
        "yHomingSpeed": 100,
        "yTravelAcceleration": 2000,
        "yPrintAcceleration": 2000,
        "zMaxSpeed": 200,
        "zHomingSpeed": 100,
        "zTravelAcceleration": 2000,
        "zPrintAcceleration": 2000,
        "xMotor": {
            "name": "X motor",
            "step": "ORIG_X_STEP_PIN",
            "dir": "ORIG_X_DIR_PIN",
            "enable": "ORIG_X_ENABLE_PIN"
        "yMotor": {
            "name": "Y motor",
            "step": "ORIG_Y_STEP_PIN",
            "dir": "ORIG_Y_DIR_PIN",
            "enable": "ORIG_Y_ENABLE_PIN"
        "zMotor": {
            "name": "Z motor",
            "step": "ORIG_Z_STEP_PIN",
            "dir": "ORIG_Z_DIR_PIN",
            "enable": "ORIG_Z_ENABLE_PIN"
        "enableBacklash": "1",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "stepperInactiveTime": 360,
        "maxInactiveTime": 0,
        "xMinPos": -110,
        "yMinPos": -110,
        "zMinPos": 0,
        "xLength": 220,
        "yLength": 220,
        "zLength": 391,
        "alwaysCheckEndstops": "0",
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": "1",
        "yHomeDir": "1",
        "zHomeDir": 1,
        "xEndstopBack": 1,
        "yEndstopBack": 1,
        "zEndstopBack": 0,
        "deltaDiagonalRod": 250,
        "deltaHorizontalRadius": 126.3,
        "deltaAlphaA": 150,
        "deltaAlphaB": 30,
        "deltaAlphaC": 270,
        "deltaDiagonalCorrA": 0,
        "deltaDiagonalCorrB": 0,
        "deltaDiagonalCorrC": 0,
        "deltaMaxRadius": 215,
        "deltaRadiusCorrA": 0,
        "deltaRadiusCorrB": 0,
        "deltaRadiusCorrC": 0,
        "deltaXOffsetSteps": 0,
        "deltaYOffsetSteps": 0,
        "deltaZOffsetSteps": 0,
        "deltaSegmentsPerLine": 20,
        "stepperHighDelay": 0,
        "directionDelay": 0,
        "stepDoublerFrequency": 80000,
        "allowQuadstepping": "1",
        "doubleStepDelay": 0,
        "maxJerk": 40,
        "maxZJerk": 0.3,
        "moveCacheSize": 16,
        "moveCacheLow": 10,
        "lowTicksPerMove": 250000,
        "enablePowerOnStartup": "1",
        "echoOnExecute": "1",
        "sendWaits": "1",
        "ackWithLineNumber": "1",
        "killMethod": 1,
        "useAdvance": "0",
        "useQuadraticAdvance": "0",
        "powerInverting": 0,
        "mirrorX": 0,
        "mirrorXMotor": {
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": "0",
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
        "mirrorZ4": "0",
        "mirrorZ4Motor": {
        "dittoPrinting": "0",
        "featureServos": "1",
        "servo0Pin": 5,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "featureWatchdog": "0",
        "hasHeatedBed": "1",
        "enableZProbing": "1",
        "extrudeMaxLength": 160,
        "featureController": 0,
        "uiPrinterName": "RepRap",
        "uiPrinterCompany": "Home made",
        "uiPagesDuration": 4000,
        "uiHeadline": "",
        "uiDisablePageswitch": "1",
        "uiAutoReturnAfter": 30000,
        "featureKeys": "0",
        "uiEncoderSpeed": 1,
        "uiReverseEncoder": "0",
        "uiKeyBouncetime": 10,
        "uiKeyFirstRepeat": 500,
        "uiKeyReduceRepeat": 50,
        "uiKeyMinRepeat": 50,
        "featureBeeper": "0",
        "uiMinHeatedBed": 30,
        "uiMaxHeatedBed": 120,
        "uiMinEtxruderTemp": 170,
        "uiMaxExtruderTemp": 260,
        "uiExtruderFeedrate": 2,
        "maxBedTemperature": 95,
        "bedSensorType": 1,
        "bedSensorPin": "TEMP_1_PIN",
        "bedHeatManager": 0,
        "bedPreheat": 55,
        "bedUpdateInterval": 5000,
        "bedPidDriveMin": 80,
        "bedPidDriveMax": 255,
        "bedPidP": 196,
        "bedPidI": 33,
        "bedPidD": 290,
        "bedPidMax": 255,
        "bedDecoupleTestPeriod": 300,
        "caseLightPin": "ORIG_FAN2_PIN",
        "caseLightDefaultOn": "1",
        "bedSkipIfWithin": 3,
        "gen1T0": 25,
        "gen1R0": 100000,
        "gen1Beta": 4036,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 0,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "tempHysteresis": 0,
        "pidControlRange": 20,
        "skipM109Within": 2,
        "extruderFanCoolTemp": 50,
        "minTemp": 150,
        "maxTemp": 280,
        "minDefectTemp": -10,
        "maxDefectTemp": 290,
        "arcSupport": "1",
        "forceChecksum": "0",
        "sdExtendedDir": "1",
        "featureFanControl": "1",
        "fanPin": "ORIG_FAN_PIN",
        "featureFan2Control": "1",
        "fan2Pin": -1,
        "fanThermoPin": -1,
        "fanThermoMinPWM": 128,
        "fanThermoMaxPWM": 255,
        "fanThermoMinTemp": 45,
        "fanThermoMaxTemp": 60,
        "fanThermoThermistorPin": -1,
        "fanThermoThermistorType": 1,
        "scalePidToMax": 0,
        "zProbeBedDistance": 10,
        "zProbeDisableHeaters": "0",
        "zProbePullup": "0",
        "zProbeOnHigh": "1",
        "zProbeXOffset": 0,
        "zProbeYOffset": 0,
        "zProbeWaitBeforeTest": "0",
        "zProbeSpeed": 2,
        "zProbeXYSpeed": 150,
        "zProbeHeight": 0,
        "zProbeStartScript": "M340 P0 S700",
        "zProbeFinishedScript": "M340 P0 S1500",
        "featureAutolevel": "1",
        "zProbeX1": 20,
        "zProbeY1": 20,
        "zProbeX2": 195,
        "zProbeY2": 20,
        "zProbeX3": 20,
        "zProbeY3": 195,
        "zProbeSwitchingDistance": 4,
        "zProbeRepetitions": 2,
        "zProbeMedian": "0",
        "zProbeEveryPoint": "",
        "sdSupport": "0",
        "sdCardDetectPin": -1,
        "sdCardDetectInverted": "0",
        "uiStartScreenDelay": 1000,
        "xEndstopBackMove": 5,
        "yEndstopBackMove": 5,
        "zEndstopBackMove": 2,
        "xEndstopRetestFactor": 3,
        "yEndstopRetestFactor": 3,
        "zEndstopRetestFactor": 3,
        "xMinPin": "ORIG_X_MIN_PIN",
        "yMinPin": "ORIG_Y_MIN_PIN",
        "zMinPin": "ORIG_Z_MIN_PIN",
        "xMaxPin": "ORIG_X_MAX_PIN",
        "yMaxPin": "ORIG_Y_MAX_PIN",
        "zMaxPin": "ORIG_Z_MAX_PIN",
        "x2MinPin": -1,
        "y2MinPin": -1,
        "x2MaxPin": -1,
        "y2MaxPin": -1,
        "deltaHomeOnPower": "0",
        "fanBoardPin": -1,
        "heaterPWMSpeed": 0,
        "featureBabystepping": "1",
        "babystepMultiplicator": 1,
        "pdmForHeater": "0",
        "pdmForCooler": "0",
        "psOn": -1,
        "mixingExtruder": "0",
        "featureAxisComp": "0",
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "retractOnPause": 2,
        "pauseStartCommands": "",
        "pauseEndCommands": "",
        "distortionCorrection": "0",
        "distortionCorrectionR": 100,
        "distortionPermanent": "1",
        "distortionEndDegrade": 1,
        "distortionXMin": 10,
        "distortionXMax": 190,
        "distortionYMin": 10,
        "distortionYMax": 190,
        "sdRunOnStop": "",
        "featureRetraction": "1",
        "autoretractEnabled": "0",
        "retractionLength": 3,
        "retractionLongLength": 13,
        "retractionSpeed": 40,
        "retractionZLift": 0,
        "retractionUndoSpeed": 20,
        "filamentChangeXPos": 0,
        "filamentChangeYPos": 0,
        "filamentChangeZAdd": 2,
        "filamentChangeRehome": 1,
        "fanKickstart": 200,
        "servo0StartPos": -1,
        "servo1StartPos": -1,
        "servo2StartPos": -1,
        "servo3StartPos": -1,
        "uiDynamicEncoderSpeed": "1",
        "uiServoControl": 1,
        "killIfSensorDefect": "0",
        "jamSteps": 220,
        "jamSlowdownSteps": 320,
        "jamSlowdownTo": 70,
        "jamErrorSteps": 500,
        "jamMinSteps": 10,
        "jamAction": 1,
        "jamMethod": 1,
        "primaryPort": 1,
        "numMotorDrivers": 0,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "invertDirection": "0",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "invertEndstop": "0",
                "minEndstop": "1",
                "endstopPullup": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
      &n
  • #define X_HOME_DIR 1
    That is to max direction but your end stops are at min position so -1 is correct value. Change it in config tool or your changes are lost on next usage. Also bette ruse the dev version if you start a new version. I is more stable then current 1.0.3 and has many bugs fixed.
  • Thank you so much!! That does work now. I have also reversed X Y an Z movement. Manual button presses as well as the homing does work now in the right directions. Just one remaining problem and this thing with 3 Extruders and a lot of other bells and whistles does what it should.
    It turns out I also have a challenge with the endstops. The printer got hall effect sensors. When in home position M119 tells me they are High. As soon as out of home position they are on Low. I also learned that they are connected to the Max Endstopps on the RADDS board. The only one Min Endstop is my BL-Touch on Z Min. Also not sure if that in this correct in a Delta printer context but thinking about it, it would make sense.
    Below my configuration on that Endstop part:
    #define ENDSTOP_PULLUP_X_MAX false
    #define ENDSTOP_PULLUP_Y_MAX false
    #define ENDSTOP_PULLUP_Z_MAX false
    My remaining issue is, that after homing the steppers "lock up". Is seems they keep on pushing against home. I wouldn't be able to move it by touching it and trying to pull it down. But I can send it down to the bed etc without any collisions via commands.
    Also not sure if "Always Check Endstops" should be ticked or not. For the moment I left it unticked...
  • Yes, most use z min for z probe just because it makes sense.
    Always check endstops false is often better so you get no false hits causing misalignment.
    Motors should stay on - often delta drop down when motor is off.
    You should also have
    more like 20mm. You can not really move too close at end stops - not even correcting leveling will be permitted without hitting endstop again. So better go down 20mm and reduce z height by that height. After G28
    M114
    should show 0, 0, z length
    G1 Z200 should then move down a bit.
  • edited April 2020
    Thanks Repetier! I followed your advice and all homing / moving works perfectly now. Also sorted some issues I then had to learn I had with the extruders. Just did the first test print and I am quite pleased that I got the latest Dev version of Repetier on my printer running.
    The adventure started because of BL Touch and I also got it going. The probe intializes and deploys as expected. The auto leveling process (G32 S2) starts as expected and the probe gets triggered. But after a few minutes fails with error below on the console:
    12:38:44.238: X:0.00 Y:0.00 Z:371.000 E:1441.0233
    12:38:56.022: Z-probe:11.109 X:30.00 Y:30.00
    12:39:04.104: Z-probe:11.271 X:30.00 Y:68.75
    12:39:12.651: Z-probe:11.969 X:30.00 Y:107.50
    12:39:12.651: Error:Cpos x square
    12:39:12.653: Warning:Invalid delta coordinate - move ignored x:19200 y:78444 z:6400
    12:39:12.655: Warning:in queueDeltaMove to calculateDeltaSubSegments returns error.
    12:39:12.656: Warning:moveTo / queueDeltaMove returns error
    12:39:21.408: Z-probe:58.390 X:30.00 Y:107.50
    12:39:21.408: Error:Cpos x square
    12:39:21.410: Warning:Invalid delta coordinate - move ignored x:19200 y:78444 z:6400
    12:39:21.411: Warning:in queueDeltaMove to calculateDeltaSubSegments returns error.
    12:39:21.414: Warning:moveTo / queueDeltaMove returns error
    12:39:37.618: buy:processing
    12:39:52.619: Z-probe:65.831 X:30.00 Y:107.50
    12:40:38.925: Z-probe:85.312 X:68.75 Y:30.00
    12:41:18.801: Z-probe:73.530 X:68.75 Y:68.75
    12:41:52.971: Error:C hit floor
    12:41:52.975: Warning:Invalid delta coordinate - move ignored x:44000 y:68800 z:-34213
    12:41:52.976: Warning:in queueDeltaMove to calculateDeltaSubSegments returns error.
    12:41:52.978: Warning:moveRelativeDistanceInSteps / queueDeltaMove returns error
    12:41:54.790: Error:z-probe did not untrigger - maybe you need to increase distance!
    12:41:54.791: Error:Probing had returned errors - autoleveling canceled.
    12:41:54.791: RequestStop:
    12:41:54.932: fatal:G32 leveling failed! - Printer stopped and heaters disabled due to this error. Fix error and restart with M999. (2)
    Where do this weird coordinates come from? Also what I noticed is that the printer starts almost mid bed with the levelling process. It definitely moves out of the printable area. Thats why the probe at the end does not get triggered anymore. The values I configured for the probing grid are on each corner 30mm smaller than the actual bed size.
    I have tried
    M502
    M500
    to reset the eeprom values but the issue remains the same. Printer is definitely no the size Repetier's auto level thinks :-)
    Any advice on this one?
  • Here are my Z-Probing and Distortion settings:
    #define Z_PROBE_PULLUP 1
    #define Z_PROBE_X1 15
    #define Z_PROBE_Y1 15
    #define Z_PROBE_X2 200
    #define Z_PROBE_Y2 15
    #define Z_PROBE_X3 15
    #define Z_PROBE_Y3 200
    #define DISTORTION_CORRECTION_R 107.5
    #define DISTORTION_EXTRAPOLATE_CORNERS 1
  • #define Z_PROBE_X1 15
    that is a rectangle for a cartesian printer. Your coordinates go euqally from negative to positive with 0,0 in the bed center. So
    #define Z_PROBE_X1 -100
    #define Z_PROBE_Y1 -100
    #define Z_PROBE_X2 100
    #define Z_PROBE_Y2 -100
    #define Z_PROBE_X3 -100
    #define Z_PROBE_Y3 100
    would be more what fits the printer. I also do not believe  probe offset. 0,0 means it is at the center of the carrier but deltas have there the nozzle normally. But with offset that reduces reachable area which is your problem - you left defined area where delta would work with your coordinates. E.g. 215, 215 means a distance of sqrt(2*215^2)=304mm and that is even beyond your max delta radius.
  • Thanks that makes and I did make changes accordingly. Actually had to bring it down to 80 and now the auto leveling completes. I still see random messages like "Warning:Invalid delta coordinate - move ignored x:4..." popping up.
    The first 2 or 3 layers are perfect, but after that the extruder moves up 5mm and prints into the air. Thought this might be due to the distortion correction being enabled but I am not able to complete a G33. It ends after 2 probes with an error.
  • Not distortion has own testing area
    which was also wrong.
    G33 L0 will show current setting, but if it was ok first layer it is not a problem 2 layer higher. More likely one of the position not reachable caused some steps not being executed.
    seems wrong to me. With diagonal 250 it seems impossible to move that much in one direction from center. This is not used in move computation but in test if a move is allowed, so reduce it to maybe 120 which I think is what you can reach.
