5 "screen and more
When will we be able to enjoy a larger 3D image on screens 5 "and larger?
So much wasted space it's a shame  :s
https://zupimages.net/viewer.php?id=20/17/ed6x.jpg
  • Since it must work on many different resolutions and printer with more or less params to be shown  the combinations are limited in usage. When the page gets reworked it might be more optimal for you or not, but I can not say when this will happen.
    it would be really great to advance the subject
  • What resolution does your display have?
    many of us have a 5 inch 800x480 screen, it is very frustrating to have a small menu on this dimension.
    I am at your disposal if you want me to test a possible update.
    Perhaps it is possible to have an adaptation on a resolution 800x480 at first ??
  • That is the same resolution the default pi 7" display has which is what we also use. It just all appears a bit smaller if you have that resolution on 5".
  • What screen is this?
  • edited April 2020
    Yes I think there are not so many different resolution cases than that.
    This is this screen:
    https://www.amazon.fr/gp/product/B07BSWWR7R/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&th=1
    I raise this update thinking because the printer community is evolving very quickly but the REPETIER service is stagnating on certain points.
    When I see what will happen in the coming weeks on the Prusa side via the WEB control (with Prusa Connect WEB), I wonder if people will break away from Repetier :
    https://blog.prusaprinters.org/pl/originalprusamininowshipping_32101/
