Z-Offset - Sensor - Repetier Host - Not LCD Screen
HI.
I have a Tronxy X5SA and the motherboard died. I am trying to quickly solve the problem by replacing the original motherboard with a MKS GEN V1.4
I do not have LCD Screen but I will manage to use it with the Repetier Host, and the PC.
I was able to solve all the configuration, except for the Z-axis Calibration.
I have this sensor for the Z-Axis on mi 3d printer.
https://www.reprap.me/tronxy-6-38v-auto-leveling-heated-bed-sensor-for-tronxy-p802m-p802e-3d-printer.html
Before trying to use the BED LEVELING or anything else. I just wnt to calibrate my z-offset of my z-axis.
But It is impossible for me.
I understand that I must set the "Offset Z EXT0_Z_OFFSET" with the distance that I have between my Noozle and my Bed when the sensor senses the bed. ¿Ok? So I must make a Z-Home and after that decrease the Z-level until i can put a A4 sheet between my noozle and my bed. And that is the distance for my "Offset Z".
But I am trying to do that, and IT IS IMPOSSIBLE to go to negative values of my Z-axis on my Repetier Host.
I need help.
Can someone help me?
Thanks in advance.
  • No, EXT0_Z_OFFSET is 0 and the reference height. The trigger height of z probe is adjusted with z probe height. You do this in eeprom normally so you do not always upload again, also reuploading does not change values anyway. It will use values from first upload normally.
