Print report / print summary
Hello everyone, I would like to have an option to print the print summary (print button to print) or an option to include the print summary in the PDF of the print report.
I hope my English is not too bad and you can understand what I mean ^^ !
Nino B.
  • The pdf report contains a summary and temperature deviation and important events. And you can print them. So sorry, don't see what you are missing in the report. Did we forget to mention some data in the report that you think are important?
  • edited April 2020
  • Ok, image really helped. I thought you meant the pdf print summary in history after the print, which contains nearly the same information, but only if enabled and after the print.
    That one is really not printable with the other content below. Currently see no way to tell browser to print only the modal. Maybe I find a solution so that it gets at least printable.
