After repair
Hey after i repair the the 3d image why isnt it showing up as repaired in ny saved fike
  • You repair the loaded version. The stored file does not get modified. Save the stl after repair if you want to keep it.
  • How can i export repaired STL in repetier?
  • Simply safe it. Repair replaces the defect with fixed version so saving will save repaired version.
