Flow and Speed automatically after a print to 100%
Hello,
is it possible that after a print the Speed and Flow to set on 100%???
The reason sometimes i change these 2 values, but if the print is finish, i forget to change it back.
  • Sure, you can use the gcode events. Just add
    M220 S100
    M221 S100
    into print finished and print aborted event and it will automatically be run at the end.
  • Ah. Ok. That's a way. Thx
