Settings parameters
When I use any slicer, the parameters of speed, temperature, table dimensions, etc. are overwritten by the settings on the repetier-server?
  • No - the server will send your gcode with the temperatures set in it. However if you change temperature manually during print that will of course change and often they are not reset in gcode so manually set temp will then stay.
    Also the speed/flow multiplier is independent of slicer gcode and might modify speed/flow - which is what they were made for. But these normally are at 100% doing no change.
