Creality CR-10S Pro config file
Hello,
Where can i find/download a Creality CR-10S Pro config file ?
I need to use in Repetier Host v2.16 and Server.
Luc
  • You can easily make your own config. Main parameter is bed position size and in host some speeds and accelerations. You can read defaults in eeprom setting normally. If they are wrong it is not that bad normally just wrong time computations.
