COREXY dual X-Carriage
edited November 2019 in Repetier-Firmware
I have built a COREXY 3d printer with 2 x-carriage. Unfortunately I only get one carriage in motion. Is it possible to control 2 x-carriage with a COREXY design with repetier???
  • I never heard about such a design, so it is not implemented I think. How does that work with 2 independent X axis?
    Apart from not knowing what it needs I think with the dual X implementation in V2 firmware it should be easy to solve. Depends a bit on the math required to implement, but there should only be one tiny function required to change. To be exactly the only function you need to change is
    void PrinterType::transform(float pos[NUM_AXES], int32_t motor[NUM_AXES]) {
    FOR_ALL_AXES(i) {
    motor[i] = lroundf(pos[i] * Motion1::resolution[i]);
    which maps position to motor position in steps. Add there your motion logic and you are done.
    Requires a due based board at the moment.
  • edited November 2019
    Thank you very much for the quick answer.
    The big advantage of this design in my opinion would be the low moving mass in Y-direction because the motors of the X-carriages are fixed to the frame.
    I tried to get the design to work with Marlin but Marlin says when compiling the COREXY with Dual X-Carriages doesn't work.
    I am currently using Repetier as my firmware. I could set the motion control in the firmware for the 1st X-Carriage to work perfectly. But when I tell the firmware that I want to use dual-X I can't get it to work :-(
    I use a Rumba Board with two stepper-driver extensions. The two stepper driver extensions are used for the mirrored z-axis stepper.
    For understanding I have attached a drawing of the belt layout.
    https://github.com/MarlinFirmware/Marlin/issues/12110
    Is Repetier V2 already usable?
  • So you use the B part just twice to have to x axis I guess?
    Would at least be no big deal to change the motor equation for that and use it with the regular dual x code and your little mod.
    V2 is already usable if your printer uses only supported hardware components. All normal features are working and especially dual x was even improved last week by me. I run a dual x with it as only firmware.
    What is missing is avr support so rumba board fails under unsupported hardware at the moment. Adding avr support is planned as one of the next big additions to it since still many use the slow but cheap 8 bit processors. Not that 32 bit costs so much more.
  • With #define DUAL_X_AXIS 0 the printer works perfectly with one X-Carriage (X1 motor).
    I have now in the configuration.h
    #define NUM_EXTRUDER 2
    #define DUAL_X_AXIS 1
    is set.
    Unfortunately the X1 motor is no longer driven when testing the movements, only the X2 motor instead :'(
    I copied the configuration.h and the FAST_COREXYZ part of the motion.cpp below.
    motion.cpp:
    #ifdef FAST_COREXYZ
    uint8_t transformCartesianStepsToDeltaSteps(int32_t cartesianPosSteps[], int32_t corePosSteps[]) {
    #if DRIVE_SYSTEM == XY_GANTRY
        //1 = z axis + xy H-gantry (x_motor = x+y, y_motor = x-y)
        corePosSteps[A_TOWER] = cartesianPosSteps[X_AXIS] - cartesianPosSteps[Y_AXIS];
        corePosSteps[B_TOWER] = cartesianPosSteps[Y_AXIS];
        corePosSteps[C_TOWER] = cartesianPosSteps[Z_AXIS];
    These are the settings that work perfectly for only one X-Carriage (X1 motor).
    configuration.h
    #define MOTHERBOARD 80
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 1
    #define FAST_COREXYZ
    #define XAXIS_STEPS_PER_MM 40
    #define YAXIS_STEPS_PER_MM 40
    #define ZAXIS_STEPS_PER_MM 200.4
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 224.2
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_MAX_ACCELERATION 200
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define EXT1_X_OFFSET 0
    #define EXT1_Y_OFFSET 0
    #define EXT1_Z_OFFSET 0
    #define EXT1_STEPS_PER_MM 370
    #define EXT1_TEMPSENSOR_TYPE 1
    #define EXT1_INVERSE 0
    #define EXT1_ENABLE_ON 0
    #define EXT1_MIRROR_STEPPER 0
    #define EXT1_INVERSE2 0
    #define EXT1_MAX_FEEDRATE 50
    #define EXT1_HEAT_MANAGER 3
    #define EXT1_PREHEAT_TEMP 190
    #define EXT1_WATCHPERIOD 1
    #define EXT1_PID_I 2
    #define EXT1_PID_D 40
    #define EXT1_PID_MAX 255
    #define EXT1_ADVANCE_K 0
    #define EXT1_ADVANCE_L 0
    #define EXT1_JAM_PIN -1
    #define EXT1_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    #define ENDSTOP_PULLUP_Y_MIN false
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define ENDSTOP_X_BACK_ON_HOME 2
    #define ENDSTOP_Y_BACK_ON_HOME 2
    #define ENDSTOP_Z_BACK_ON_HOME 2
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 1
    #define INVERT_Y_DIR 1
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 342
    #define Y_MAX_LENGTH 340
    #define Z_MAX_LENGTH 500
    #define X_MIN_POS -8
    #define Y_MIN_POS -25
    #define Z_MIN_POS 0
    #define PARK_POSITION_X -8
    #define PARK_POSITION_Y -25
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 10
    #define HOMING_FEEDRATE_X 60
    #define HOMING_FEEDRATE_Y 60
    #define HOMING_FEEDRATE_Z 10
    #define ZHOME_PRE_RAISE 2
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 60
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 60
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 10
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 180
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 180
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 10
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_RESOLUTION 0
    #define X2_STEP_PIN   ORIG_E2_STEP_PIN
    #define X2_DIR_PIN    ORIG_E2_DIR_PIN
    #define X2_ENABLE_PIN ORIG_E2_ENABLE_PIN
    #define FEATURE_TWO_YSTEPPER 1
    #define Y2_STEP_PIN   ORIG_E3_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E3_DIR_PIN
    #define Y2_ENABLE_PIN ORIG_E3_ENABLE_PIN
    #define FEATURE_TWO_ZSTEPPER 1
    #define Z2_STEP_PIN   ORIG_E4_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E4_DIR_PIN
    #define Z2_ENABLE_PIN ORIG_E4_ENABLE_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 2
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET -0.3
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 0
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_PIN -1
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_USE_MEDIAN 0
    #define Z_PROBE_HEIGHT 40
    #define Z_PROBE_DELAY 0
    #define FEATURE_AUTOLEVEL 0
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 20
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #undef SDCARDDETECTINVERTED
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 0
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 1
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 1
    #define LANGUAGE_IT_ACTIVE 1
    #define LANGUAGE_ES_ACTIVE 1
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 1
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 1
    #define LANGUAGE_TR_ACTIVE 1
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
    #endif
    In the first two requests I tried to upload some pictures. Unfortunately this doesn't work? You know what I'm doing wrong?
    Again, thank you so much for your support.
  • That can not work in V1. You need to drive 4 motors with 3 coordinates, so you need an independent 4th motor that does not exist in V1. That is why I said to do it in V2 where we support up to 7 independent motors. There dual x uses A axis as second x axis motor so you can define a coordinate mapping to that motor as well.
  • Oh, that's so sad. I have already rebuilt everything :-(
    OK, what kind of board should I get if I want to use the V2 optimally? Would the SKR V1.3 / 32bit board be the right choice?
    Is it safe that my belt layout will work with a compatible board in combination with the V2 firmware?
    Can V2 BLT and TMC2130 work with stallguard?
  • No SKR V1.3 is not due compatible. We are working on more processors, but for now I'd go with a RADDS + Due to be safe. Hope to have RUMBA32 working beginning of next year. Already bought one. Would be easier to use with TMC2130 which are already supported in V2.
    What is BLT?
    Stallguard in principle works, but in your special case where 3 motors stall in parallel I can not say what happens. For use as endstops that might not be best idea. Pure cartesian printers will surely give better signals here.
    Of course you still need to teak the source code in the function I showed you before.
    I'd suggest Ultratronics PRO. It supports 7 motors, has 32bit CPU and lots of other cool features. Not sure though if CoreXY support for it has been implemented in V2.
    ...Talking about CoreXY - during the last 3 years I went full circle - from Cartesian to CoreXY with 2 belts then to CoreXY with single belt, then back to Cartesian. While everyone gets excited about simplicity of CoreXY kinematics (including myself in the past), the biggest issue they have is the length of the belts. With small printers that may not be a problem, but when you go bigger, and IDEX usually has bigger than average print size, then you may start experiencing print quality degradation. I don't want to discourage you, but this is something you may want to consider in your future projects.
  • Ultratronics works with V2 and is overall a good board. The only thing I miss is an eeprom. So you need to use sd card to store what otherwise would be stored to sd eeprom.
