Which LCD Display for RADDS + Arduino DUE
In the configuration tool I see a few options for LCD display.
I found "SparkLCD + Adapter  on RADDS lCD Port"  is it this one:
https://sparklab-shop.de/elektronik/29/sparklcd-grafik-display-fuer-radds-board
If using this display will the micro-SD card slot on the RADDS also work?
  • Yes, since the controller has no sd card slot that one will keep it's configuration and still work.
