webserver
im trying to setup the web server in front on repeater server on the faq page. I have repeater server on my raspberry pi do you install the web server on a second raspberry pi? I can't get it to work on the same pi as repeater server install.
  • Our image has already nginx as web server in front of Repetier-Server configured. So you can use the normal port 80 to access it.
    Or did you want something else I did not see?
