Height map tool not available
I am using Repetier host and Flyingbear P905X printer with default firmware (Merlin).
I would like to use the Height map tool to level the bed but the button is not available (the menu entry is disabled). How can I enable it? Why is not working?
  • You can't. It only works with repetier-firmware which is also why it is disabled.
