View log online if can't connect to the printer
Hi! I can not see the log meassages online if i can't connect to a printer. Will be good if i can see log online without connect for
diagnostics.
  • Normally communication is not logged, so console only shows last 1000 lines when connected.
    For full logs you need to enable logging in printer menu. These logs can be downloaded and viewed any time.
    Yes, but will be good if i not need download it and can see it in online mode.
  • Yes, would be nice nut currently not implemented. Since logs can be quite big that is a not trivial task. But some day it will be available:-)
      It can show logs over the last 24 hours or 1-2 hours it will be good for diagnostics connetct.
  • But logs are written until the process is finished and these include also print logs if enabled. So it should work for all and also if log is still be written to. But it is on my long todo list for nice features.
