Timelapse 4 second
edited September 2019 in Repetier-Server
Timelapse after rendering is 4 seconds. I changed different settings, but for some reason,
regardless of the print time, the time-lapse is always 4 seconds.
pi3b+
0.92.1
  • Print time depend on frames per second and number of images. If print have nearly same layer count and you make one image per layer it will result in nearly same time.
    If you check in the images do you see there more images than used in the video?
  • Yes, just before I went to the forum and see if there are any answers, it occurred to me that frame per second is not like in computer games, the higher the better. But thanks anyway!!!
