Screen 5 pouces
edited August 2019 in Repetier-Informer App
Hello,
I am calling for your help because I can not operate the server with a 5-inch screen. I have no problem with my 3.5 inch screen but as soon as I plug the 5 inch raspberry the server does not run as usual. This is some pictures.
The last line is: Stated D-Bus System Message Bus
and after nothing is displayed
Could you tell me what's wrong ?
  • Not really. Looks like it is still on text screen with disabled message visualization. Wondering that you see the messages at all as we have disabled it I thought.
    What you can do is login and then run
    dmesg
    to see all messages.
    Also Running
    xinit -- -nocursor
    manually - which is the command we use to start x with chromium should give you more infos about what is going wrong. Guess it has to do with display driver and configuration. Each display has it's different drivers and required settings to get x system working.
