Power On/Off button
Hi! How use the button? I want use the buttion on raspberryPI (use GPIO) but i can not see the settings.
  • The code just sends M80 or M81 to printer. It is up to printer and it's firmware to turn power on/off. Most do NOT support this feature. It requires a ATX power source that delivers always 5V standby and only switches 12V depending on a pin signal.
    For Raspberry you need to create a custom command that you then call from server interface. See user manual->advanced setup on how to do that.
    Oh. Ok. I do it but now it placed in general menu. Can i add it to menu of the printer.
  • From the manual Advanced Setup
    	     Commands are normally visible in the global menu. If you want one to appear only in
    	     in the printer menu, add the attribute "slugname" to command. You see the slugname
    	     when you select a printer as part of the path.
    with that it knows it is printer related and moves it to printer context menu.
  • In /var/lib/Repetier-Server/database/extcommands.xml:
     <command>
                    <name>printerOn</name>
                    <execute>bash /home/pi/scripts/printerOn.sh</execute>
                    <confirm>Really turn on the printer?</confirm>
                     <!-- Define if command should show up in local printer interface, default true.-->
                    <local>true</local>
                    <!-- Define if command should show up in remote printer interface, default true.-->
                    <remote>true</remote>
                    <slugname>Sprinter</slugname
            </command>
            <command>
                    <name>printerOff</name>
                    <execute>bash /home/pi/scripts/printerOff.sh</execute>
                    <confirm>Really turn off the printer?</confirm>
                    <local>true</local>
                    <slugname>Sprinter</slugname>
            </command>
            <execute name="play" allowParams="true">sh /home/pi/scripts/printerOn.sh</execute>
            <execute name="off" allowParams="true">sh /home/pi/scripts/printerOff.sh</execute>
    It not work for me.
  • You added it as tag, try as attribute
       <command slug="Sprinter">
    looking into code I saw that slugname must be slug as attribute name.
    Now it looks like:
     <command>
                    <local>true</local>
            </command>
            <command>
                    <local>true</local>
            </command>
    </config>
    And not work.
  • NOOO into the command tag you already have like
                    <local>true</local>
            </command>
                    <local>true</local>
            </command>
    </config>
                    <local>true</local>
            </command>
                    <local>true</local>
            </command>
    </config>
    Thx! Work!
