Big Job - Problem
Hello, I have an HP client for Repetier server. I use 6 printers. Unfortunately, I have provided 3 of them with 62h orders (Gcode). When I called the Repetier server today after about 55h, the printers stopped and the server rebooted. : / is there a problem if the server has to work too many jobs in the long run
  • The job duration is no issue since server doe snot read it into ram. So it makes no difference if you run many short jobs or a long job.
    When you say server rebootet do you mean the HP or repetier-server?
  • I'm talking about the repetier server
