Hot to send a Command
How can I send the command "RESTART_FIRMWARE" to my printer (with Klipper firmware installed)? It seems like repetier server can only send valid G-codes to the printer and alls other commands will be ignored
  • For non gcode commands you need to add # at the beginning of a line
    #RESTART_FIRMWARE
    will send it 1:1 to firmware.
  • Ah, thank you. Where can I find this ind the manual. I only found the server commands with @ in front of the command.
  • Good point. Have added it to console description for next release.
